What I would like to do:
- using my router, create another highspeed access point upstairs in the bedroom and another one in the basement (finished).
What I have:
- Dlink Gaming GB Router. It has a wireless broadcast, but that is still limited to 54mpbs? I think.
Questions:
Do any of these wallplug extenders really work?
What is the max speed of data transfer?
(if they work and work faster than wireless) What is a good one to buy?
I'm in the military and move a lot, so a permanent wired solution isn't an option. I need something that can move easily. Wireless is okay for websurfing, but just not good enough for online gaming.
The stuff does work generally the speed of a 10 base network connection. All advertise higher, but those speeds are best case. Here is a link explaning in more detail. http://www.homepna.org/ I have used the 2 wire in a couple of location. It works but speed vairies greatly, depending what other equipment is on the line.
Just checking the specs -- there's a new "HD" line from Netgear that's faster and also incompatible with the above products. So it'd probably be a mistake to buy the old line products.
An HDX101 may coexist with HomePlug 1.0 products but it is not compatible or interoperable with XE102
Wall-Plugged Ethernet Adapter, WGX102 Wall-Plugged Wireless Range Extender, XE104 85 Mbps Wall-Plugged
Ethernet Switch, XE103 85 Mbps Wall-Plugged Ethernet Adapter.
The new "200Mbps" adapters from Netgear are based on a prorietary chipset from a company in Spain called DS2. They don't really live up to the speed that they hype. They are about as good as the ones out there that are based on the HomePlug standard and run at 85Mbps like this one: Actiontec HLE08500-01 Powerline Adapter.
I read that report and it's highly optimistic and uses only test conditions and no "real world" data steaming. Try sending some streaming HD video over any distance and it's completely unwatchable. We tested several of the Netgear HDX101 adapters and their claims of being able to coexist with previous powerline products (namely their HomePlug 1.0 and Turbo products). The performance of the new adapters was decent when sending data, but steaming HD video was unwatchable and they pretty much shut down the legacy devices.
