Tom's Hardware > Forum > Home Theatre > HDTV > Strange problem with panasonic HDTV set top box
Forum Home Theatre : HDTV - Strange problem with panasonic HDTV set top box
Archived from groups: alt.tv.tech.hdtv (More info?)
Perhaps someone who owns a TU-HDS20 DirecTV receiver can help me. The
receiver loses the satellite signal after the guide as been acquired. After
the data acquisition process is complete after I plug in the receiver I have
0 on my signal meter and all channel are unavailable. If I check my signal
meter before the guide is acquired it is 91%. I have been playing with
this for some time and am stumped.
On a related note I purchased the unit from ebay. I emailed the seller of
my concern. He said he doesn't accept refunds and that nowhere in his
auction did he state that the receiver works, which is true, but the auction
does not state that is doesn't work either. Do I have any recourse here or
a I out of pocket if I can't get this thing to work.
Thanks for any help
Regards
Ryan
Sponsored Links
There are some strange things that can happen.
1. If you have a multi satellite with more than one LNB, one may be bad. The
channel you select determines which LNB is currently used.
2. The receiver provides the power for the LNBs. The receiver may be
defective.
3. The receiver may be set to recieve local channels. The TU-HDS20
automatically selects input from the external RF antenna connector, so no
signal is received. You may need to get Directv to download new software to
your receiver to fix that problem.
Good luck!
"Ryan2000" <Ryan2000@allstream.net> wrote in message
news:Dcflc.3580$Xy3.14946@tor-nn1.netcom.ca...
After
have
signal
auction
or
> Thanks for any help
> Regards
> Ryan
Reply to JAS
Thanks for the input.
Regards
Ryan
"JAS" <spin500@cox.net> wrote in message
news:BqAlc.12666$pJ1.2252@lakeread02...
The
> defective.
to
> Good luck!
> After
> have
> signal
of
> auction
> or
> > Thanks for any help
> > Regards
> > Ryan
Reply to Anonymous
There are 613 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
  • 01:00 dpnaugle won the Freshman badge
