Archived from groups: alt.tv.tech.hdtv (More info?)
I was browsing through some HDTV "stuff" and noticed that a lot of the
HDTV Tuners (Samsung are the ones I'm looking at) say that you can
choose to have it output in 480i format (and it has RCA outputs). Does
this mean that I could pick up the HDTV Tuner and hook it up to a
regular television set? (I'm assuming that it would show widescreen
stuff in letterbox?). I'm really wanting HDTV for the digital
reception, but I have no idea how long it will be before I can afford
an HDTV display (and besides, I'd rather wait for the plasmas to come
down in price rather than settle for a projection). Getting the tuner
now and using my pretty decent 32" television would work really well
for me. Again, I know it won't be showing the stuff in hi-resolution,
I'm just interested in the digital reception at this point.
"Michael Gaskins" <mbgaski@clemson.edu> wrote in message
news:27b46bab.0405021911.748eaf46@posting.google.com...
Yes you can use an STB for a "regular" NTSC 4:3 or 16:9 television. The 480i
picture will look better than what you normally get from DVD's so it's a
very nice upgrade. Most STB's have aspect ratio controls that will allow you
to choose letterbox and all of the other popular aspect ratio distortions. I
set up an NTSC OTA only friend of mine with my old Panasonic HD tuner and
save for the fact that it's a shitty/slow tuner, she is ecstatic about the
quality of picture she is receiving from rabbit ears.
Yes, this is EXACTLY what one of the Samsung's or other OTA tuners can do.
I have a Samsung and love it. I currently have it output to my Toshiba RPTV
in 480i and the picture from the HD broadcasts are BETTER than DVD quality.
If you have a progressive display you can use 480p instead of 480i.
Not only that but some of the older Samsung tuners (like mine) will also
output RGB to a computer monitor which will give you full progressive HD.
Grab one up and you're part way there. But be aware that it seems that many
manufacturers are going to be including OTA tuners in new HDTV offernings.
-- Bob
> Thanks.
: I was browsing through some HDTV "stuff" and noticed that a lot of the
: HDTV Tuners (Samsung are the ones I'm looking at) say that you can
: choose to have it output in 480i format (and it has RCA outputs). Does
: this mean that I could pick up the HDTV Tuner and hook it up to a
: regular television set? (I'm assuming that it would show widescreen
: stuff in letterbox?).
Yes! It works beautifully.
I do it in my upstairs theatre on an older Pioneer 46" 1.50:1 RPTV.
The picture is outstanding: DVD quality.
: I'm really wanting HDTV for the digital
: reception, but I have no idea how long it will be before I can afford
: an HDTV display (and besides, I'd rather wait for the plasmas to come
: down in price rather than settle for a projection). Getting the tuner
: now and using my pretty decent 32" television would work really well
: for me. Again, I know it won't be showing the stuff in hi-resolution,
: I'm just interested in the digital reception at this point.
: Thanks.
Only the older Samsung tuners output RGB to a computer monitor? Why
aren't the newer ones as flexible? It seems to me that there are
probably a lot more folks around with good, old, cheap, high
resolution computer monitors than there are with new, expensive, high
resolution TV "monitors". Aren't they reducing their market by leaving
off this capability? Is there any way to adapt the output from current
tuners to RGB monitors?
Yes. But keep in mind that a 32" HDTV with integrated tuner is now selling
for $810:
"Lawrence G. Mayka" <lgmayka000@ameritech.net> wrote in message news:<rqwlc.2213$eH1.1355880@newssvr28.news.prodigy.com>...
> for $810:
Yes, but that's a CRT and it's 4:3 ratio, as well as being the same
size as my current NTSC set. So I wouldn't be gaining any size or even
widescreen from the ugprade. That's just not a big enough jump for
me. As it is, you can get the standalone tuners off of ebay for
~$150. To me that's a much better upgrade. I'll likely get a big
(50"+) widescreen monitor in the future, and if it has no tuner then I
will already have one. If it has one built in, then I'll either move
this tuner to another TV in the house or let my parents have it (since
I doubt they'll EVER upgrade to an HDTV. If NTSC blacks out they'd
likely just stick with the satellite).
Hi Joe,
I imagine the newer ones don't have the circuitry to save manufacturing
costs.
I have the Samsung SIR-T150 which has the RGB Circuitry. It is a very
solidly buit unit and is mostly made out of metal. But then again this unit
was a $700.00 item when it was new.
The next newer unit, the SIR-T151, I think has a molded plastic case and no
RGB Circuitry. I don't think any of the newer ones have it.
I believe there are converters but I've never looked into them. You would
need a component to VGA converter I guess.
-- Bob
"Joe Moore" <munged@bad.example.com> wrote in message
news:fvsc90htqbv4r8u4aqioaj01288rndbccv@4ax.com...
> joemooreaterolsdotcom
>Hi Joe,
>costs.
>Here's a PDF for this unit:
>http://www.ravenimaging.com/forsale/SIR-T150/SIR-T150_set_top_box.pdf
>You can find them on eBay reasonably priced.
Thanks for the response. I'm shocked at how expensive these tuners
are. I think I'm going to wait until the price comes down a bit. I did
see a place which will rent one (SIT-T150) for 10 bucks a day to try
out, so maybe I'll try that.
>>Hi Joe,
>>costs.
You should be shocked. In other countries OTA DTV receivers that work
with current analog TV sets cost as little as $40. (UK)
The manufacturers in the US of 8-VSB receivers have promised as far back
as 2000 that inexpensive OTA 8-VSB receivers for the US market would be
available SOON.
