Tom's Hardware > Forum > General Networking > VPN, VoIP, Video Conferencing, Remote Connections > Problem uploading TightVNC extension in SSLExplorer
Forum General Networking : VPN, VoIP, Video Conferencing, Remote Connections - Problem uploading TightVNC extension in SSLExplorer
:( error message is as follows, thanks for any help
extension.xml is not a loaded application bundle
java.lang.Exception: extension.xml is not a loaded application bundle
at com.sslexplorer.extensions.store.ExtensionStore.getExtensionBundle(ExtensionStore.java:645)
at com.sslexplorer.extensions.store.ExtensionStore.installExtension(ExtensionStore.java:826)
at com.sslexplorer.extensions.ExtensionUploadHandler.performUpload(ExtensionUploadHandler.java:46)
at com.sslexplorer.vfs.actions.UploadAction.onExecute(UploadAction.java:84)
at com.sslexplorer.core.actions.AuthenticatedAction.execute(AuthenticatedAction.java:223)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:419)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:224)
at com.sslexplorer.core.CoreRequestProcessor.process(CoreRequestProcessor.java:200)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:763)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:405)
at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:520)
at com.sslexplorer.core.filters.CompressionFilter.doFilter(CompressionFilter.java:84)
at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:511)
at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:463)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:525)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1457)
at org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:514)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1409)
at org.mortbay.http.HttpServer.service(HttpServer.java:889)
at org.mortbay.http.HttpConnection.service(HttpConnection.java:829)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:998)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:846)
at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:244)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:345)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:530)
Sponsored Links
BTW I'm using Windows XP Media Center Edition Could this be a problem?Also, I was able to install the PuTTy extension :(
Reply to trike203
Could you enlighten us on your resolution? I am running into the same issue and have tried everything I've found so far without any luck. Thanks.
Reply to marmanw
There are 1128 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
