Tom's Hardware > Forum > Games General > Games General Discussions > nwn usin 100% processor power
Forum Games General : Games General Discussions - nwn usin 100% processor power
Archived from groups: alt.games.neverwinter-nights (More info?)
yea somehow nwn usin 100% processor power even when i start the game goto
multi play and it alrdy usin all off it, anyone know why?
i got pentium 4 2.4 gig,
512mb ddr pc2700 and
sapphire radeon 9600 pro 128mb
this runnin with win xp home edition.
soundblaster live 5.1
Sponsored Links
"Diablo" <Blablabla@blablabla.bla> wrote in message
news:10e084d6r4po01@corp.supernews.com...
Are you saying you'd rather the CPU run at less than 2.4 ghz? Or your CPU is
running at ~100% CPU usage?
I run a 850mHz and it does the same thing. At least that's what the XP
processes screen says.
Reply to Anonymous
is
> yea i sayin it runnin at 100% usage, i think that kinda weird sinds this
only game that does that, when i play
joint operationss its like 20% max , but most of time 0! .
Reply to Diablo
You're misreading it, then. Pretty much any serious application running
in the foreground will take up upwards of 90% of your CPU cycles. Maybe
not for the instant at which the little applet displaying the processes
running is on top, so to speak. It couldn't be 100%, either, as your OS
has lots of other tasks to deal with. If a single process was taking up
100% of CPU cycles, your computer would immediately crash.
But yes, NWN should be taking up as close to 100% of your CPU cycles as
it can. Like most computer games, it's very CPU intensive. And there's
no benefit to having unused CPU cycles, anyway. Your CPU is there to do
work.
Reply to Anonymous
> work.
Good point, how else are you supposed to get the maximum performance on any
game, not just NWN. Of course it is as close to 100% as possible. The reason
you are seing 20% usage for JointOps, is (most likely) that the game is
idling while you're looking at the task manager. (I seriously doubt it would
even run using just 20% of CPU capacity, even with 2.4 GHz (20% would be
roughly 500 MHz))
Reply to Vellu
"Vellu" <velimala@hotmail.com> schreef in bericht
news:YI0Ec.437$w74.325@read3.inet.fi...
> > work.
any
reason
would
> roughly 500 MHz))
> owk i see u guys made a point but i wasnt idle when i checked little task
up left in jointops, and another thing can it be possible most tasks R done
by Gpu instead of cpu?
i know nwn uses opengl, but this not the case with jointops maybe that has
somethin to do with it?
Reply to Diablo
damn! even when i start up game and do nothin it uses like 80-99% of CPU
power!!
this insane!
Reply to Diablo
Try this:
Open the Task manager, select the Performance tab (the one with the graph)
See the low CPU usage, maybe 10%
Open Joint Ops
Play Joint Ops for 30 secs / 1 min
Switch to the Task Manager window
The graph will show CPU usage for the playing time, and I'd be surprised if
you found it was any less than 90%. I mean, try loading an explorer window
and watch the usage spike for the disk access....30% at least. Unless you've
gone down the SCSI route of course....
news:10e2eajoiagb6c1@corp.supernews.com...
> power!!
> this insane!
Reply to alex
Perfectly normal, happens with every single game (3D) I have...As it should.
What else would you like the CPU to be doing while you're playing the game?
(even when waiting in the menus)
> power!!
> this insane!
Reply to Vellu
Argh! maybe i havent been clear about this, but
i mean i startup the game, "puchin play button"
then when all cinametics r done and all, then i do
Nothin! i dont start single playin game Or multi whatever, just nothin, and
it still usin 80-99% cpu. and i have this from windows task manager.
Reply to Diablo
news:10e39h5cbooq75f@corp.supernews.com...
and
It's a normal condition. If you can play the game, what difference does it
make?
Windigo
Reply to Anonymous
Exactly, it does show 80-90% even while idling in the menu. Mine appears to
take all available cpu cycles (nwmain.exe) 90-95% which keeps total at 100%
(while idling in the menu).
But it does seem to 'make room' whenever I do something else, for example
start IExplorer; cpu cycles for nwmain.exe drops to 40-50% for a while, then
when IE has started it goes back to 90-95%. Which basically means it always
"reserves" all unused cycles for itself, even though it may not need them at
the time. This is to ensure, that while playing the game it always has the
maximum amount of processing power allocated. I believe this is quite common
for games in general.
"Windigo" <windigo(a)@paganplanet.com> wrote in message
news:BXhEc.23405$rh.13675@okepread02...
> and
it
> make?
> Windigo
Reply to Vellu
news:10e2dv32dmk67c5@corp.supernews.com...
as
do
> > > work.
> any
> reason
> would
> > roughly 500 MHz))
task
done
What do you mean not idle? what is "little task up left in jointops"? It all
depends on what is being done and how the game enigine is written as to if
the GPU or CPU are written.. But the GPU only runs is the CPU tells it too.
I havn't a clue what the game engine uses or how they implimented it. it is
possible... i doubtb it
Reply to Anonymous
> and
it
> make?
This thread is starting to molt into Trolling me thinks.
Reply to Anonymous
join a game then press tilde key ~ enter Fps, then u see what i mean. :^)
Reply to Diablo
news:10e5ffktn0d8v1f@corp.supernews.com...
Which game NWN or JointOps? This shows more than just the FPS (Frames per
second)?
Reply to Anonymous
yea in jointops it shows, more fps, cpu, 2 more but what they r, got no
clue, but who cares the demo workin smoothly :-).
Reply to Diablo
news:10e696b341bv69b@corp.supernews.com...
well um ok?
Reply to Anonymous
In article <10e696b341bv69b@corp.supernews.com>, Diablo
You might get more help if you posted in intelligible English. As it
is, I'm sorry but I haven't the faintest idea what you're on about.
See also: <http://www.catb.org/~esr/faqs/smart-questions.html>.
Reply to Anonymous
Um... No. What is happening is that the game is running a loop:
1. Read user input (check if a key or mousebutton has been pressed or the
mouse has been moved and if so, set some variable accordingly).
2. Check how much time has been between the previous time we were in this
step. Then make whatever changes should happen in the gameworld in this
time difference.
3. Draw the screen.
4. Go to step 1.
A loop like this will always take up all the available CPU power. Why
wouldn't it ? After all, there's always more work to be done.
So no, it doesn't reserve any cycles to itself, it simply never sleeps
(tells the system to stop running it and resume running it after a given
time) or blocks (sleeps waiting for user input or a disk read/write or
some other I/O function to finish).
Reply to Anonymous
"Richard Buckle" <richardb@sailmaker.co.uk> wrote in message
news:010720040519148358%richardb@sailmaker.co.uk...
Concerning the faq link:
If you can make it past the elitist attitude of the author, the faq is a
good outline for problem solving. However the "help those who can help
themselves and to hell with the losers" attitude has a familiar ring. It
assumes that one person or group of people has the right to pass judgement
on anyone based on their requirements or expectations. Anyone who fails to
meet those requirements are labeled inferior or "losers" and therefore not
privy to nor deserving of knowledge and benefits controlled by the group.
In the past this judgement has been based on race, religion, ethnic origin,
sexual orientation and even dominant handedness. Now we can include
language use.
Windigo
(who should never read news groups before breakfast)
Reply to Anonymous
Yes, sounds sensible enough...but in the menus aswell? Where absolutely
nothing takes place (unless you click something). Not being a programmer
myself, I can't really say that I know what the procedure is that games use
to always use/reserve as much of cpu power as they can, except the fact that
it is in my opion a wise thing to do (game performance wise).
> time difference.
> 3. Draw the screen.
> 4. Go to step 1.
Reply to Vellu
"Windigo" <windigo(a)@paganplanet.com> looked up from reading the
entrails of the porn spammer to utter "The Augury is good, the signs
say:
>language use.
There's a difference though.
A person can't help what their race, religion, ethnic origin, sexual
orientation etc are.
Bad language use like the above is pure laziness, and that CAN be
helped. It's the written equivalent of talking with your mouth full and
it gets in the way of communication.
Phonetic "shortcuts" also make it considerably harder for people whose
native language isn't english to understand, since those shortcuts DON'T
sound like what they're being used to represent in their language..
Xocyll
I don't particularly want you to FOAD, myself. You'll be more of
a cautionary example if you'll FO And Get Chronically, Incurably,
Painfully, Progressively, Expensively, Debilitatingly Ill. So
FOAGCIPPEDI. -- Mike Andrews responding to an idiot in asr
Reply to Anonymous
There's a swirling... thing in the background of some of the menus.
Besides, the menus presumably use the same input engine as the rest of the
game, and that can't block (sleep untill you press a key), otherwise
nothing could happen in the game until you pressed a key (because the loop
would be stuck on the "read user input" part and thus could not advance to
updating the gameworld and redrawing screen until it got some input)...
So what I'm trying to say is, that it would require explicitly telling the
OS to not run the game for a while (a few microseconds) to prevent it from
using 100% CPU. That would cause a performance hit, because each time the
loop was run the program would simply wait for a while, thus taking longer
to complete the loop and thus being unable to go through it as many times
per second...
The game is using all the CPU it can get, which, as you pointed out, is a
wise thing to do, because the screen is redrawn once per loop, so loops
per second = frames per second.
But it's impossible for a program to reserve CPU beyond what it's actually
using. All CPU cycles must do something. That's why operating systems have
an "idle" task, a program which does nothing but loops endlessly; whenever
no other program can be run (because they're all sleeping or blocked),
this idle loop is run to waste time untill it's time to wake one of the
other programs or one of them unblocks, at which point execution jumps to
that program. If there's several runnable programs at the sime time, then
the execution jumps from program to program, executing each a short while
and then jumping to next, giving an illusion of concurrent execution. How
long each program is run depends on its priority: the higher the priority,
the longer the program is run before switching to the next one.
So, all a program needs to do to use all the CPU is to never sleep or
block, and have no other CPU intensive programs running at the same time.
It doesn't take any special procedure to use 100% CPU; it takes special
procedure (sleeping or blocking) to avoid that.
Most programs use little CPU while they're running, since they do nothing
but wait for you to press a (mouse)button, and block until you do. They do
use lots of CPU while starting up, because they are opening windows,
loading settings and other data and generally preparing for accepting
commands. A program that's working will always try to use 100% CPU (but
this work usually involves input and output, which are usually done in a
blocking manner, so the actual usage is most of the time be less, since
the program blocks occasionally), regardless of CPU speed, and will simply
get their task done quicker in a faster system.
I am a programmer, altought not a very good one :(.
Reply to Anonymous
"Xocyll" <Xocyll@kingston.net> wrote in message
news:qiu8e0hdgbu78dijl6f782qvk23dkb9oph@4ax.com...
> say:
> >language use.
> Xocyll
Diablo is likely part of an online community that uses that style of
communication. It's perfectly acceptable in many groups. BTW did you
bother to read the faq? To be truthful, I agree with you on the subject but
the attitude of the faq that Buckle advised reading was IMHO too arrogant to
dismiss and made me question my attitudes. And as I noted, I really
shouldn't respond to posts before I have breakfast.'-)
Windigo
Reply to Anonymous
"Windigo" <windigo(a)@paganplanet.com> schreef in bericht
news:IB3Fc.41880$rh.30872@okepread02...
> > say:
> > >language use.
> > Xocyll
but
to
> Windigo
english aint my language, and about my style of postin
its just that after puttin in a quesion and get questions in
return kinda confused me, wasnt my first post clear enuff? i guess not.
i did go to fag just now, all it did was scrollin tru it. why? well it wasnt
in my language or afailable.
i try to use common sens. to many people tryin to understand what i sayin by
dictatin every darn letter.
maybe it helps readin between the lines :-). Aka gray area, for some people
this a huge void.
i not pointin in anyone direction cause this only make me hit mid air.Lol
doesnt it concern u guys a program usin 100% of cpu power, i not sayin it
shouldnt, but i like to have my pc
in top shape. i alrdy have to many crashes in a big party 5+people, this
seams common in path of ascension sinds
people dropin like flies in a very actiff 5+ party.
Reply to Diablo
news:10eac8k9q7mt476@corp.supernews.com...
Snip
wasnt
by
people
> this a huge void.
Disregarding language use, ;-) I have a 1.7 MHz system and my wife is
running a 2.6 MHz system. Both have 1 GB RAM and both use 100% of the CPU
when running NWN. I tested it on a 700 MHz machine with 512 MB RAM and the
results were the same. I don't think it's a performance issue.
Windigo
Reply to Anonymous
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
| say:
fails to
therefore not
origin,
|>language use.
Well, you can change what your religion and sexual orientation are, for
starters. Mind you, that has probably not the slightest bearing on the
question itself unless it directly concerns them, unlike correct
spelling, grammar and politeness.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFA84ccwjjtrLvNMRARAizzAJ9wYutqLCkHJTVL20oeV0FV7IY5KwCdHUuM
QKNPxrw6qJHMvavaBlAU9t4=
=ujzS
-----END PGP SIGNATURE-----
Reply to Anonymous
news:IseFc.43414$rh.34130@okepread02...
> Snip
the
> Windigo
I use 3GHz system with 1Gig RAM and 128MB Graphics and it also uses 95%+ of
CPU. Not really an issue, because the CPU will lessen that usage if
something else tries to run in the background at the same time. I really
can't see why Diablo is getting so worked up about this issue. It's like
saying he doesn't want to use his entire brain thinking about something,
just in case he needs to suddenly think about something else at the same
time. Room will be made to accomodate, regardless.
Reply to Anonymous
"Paul Rhodes" <rhodes@allwayscrackingbars.com> wrote in message
news:OEmLc.9707$K53.4183@news-server.bigpond.net.au...
> > Snip
CPU
> the
> > Windigo
of
You sure about that with all of us??? muhahahaha!
Reply to Anonymous
There are 975 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
