I'd appreciate any help here...
After reading much about overclocking I was going through a very calculated and methodical procedure to overclock the CPU and RAM (using the Nvidia Ntune overclocking utility) on my new machine. On each step the machine tested stable and OK. On the last tweek the system did not boot properly so I went back to the BIOS and dropped the reference clock back down a notch and it booted fine. I restarted the machine one more time to test and now it will not boot at all. It seems to start the boot sequence then just stop. It seems to look at the CD/DVD drive and then do nothing else. Nothing on the monitor at all. I have checked for loose connections, checked off/on switches and have installed an older HD to see if it would boot from it (have also tried booting from recovery CD's, etc) all to no avail.
What could have happened here??? Did I possibly roast something or could it be just hardware failure on a new machine?
What do I need to do to recover my brand new machine????
Any help would be appreciated!
