Archived from groups: microsoft.public.windowsxp.basics (
More info?)
Yes. You must remove the programs from the startup folder and from the
startup section of the registry. If you just want to test, use selective
startup.
Colin Barnhorst [MVP Windows - Virtual Machine]
(Reply to the group only unless otherwise requested)
"If_Its_Junk" <If_Its_Junk at hotmail dot com> wrote in message
news:%23ptueZiDFHA.3972@TK2MSFTNGP15.phx.gbl...
> "Ron Martell" <ron.martell@gmail.com> wrote in message
> news:jjai01l0tc2do7ive0d18i5g2b6680mc54@4ax.com...
>> "If_Its_Junk" <If_Its_Junk at hotmail dot com> wrote:
>> >maybe
>> >I was working on a friends computer and cleaned out some viruses and a
> whole
>> >heap of malware/spyware.
>> >There were some items in msconfig startup that I did not recognize and
>> >turned them off. Yet when I rebooted they were all turned back on again.
> I
>> >also got a message at boot that said something to the effect that my
>> >configuration had changed, and I clicked on the OK button.
>> >How do I get the things I have turned off to stay off?
>> What are the specific items that keep coming back?
>> What programs did you use to detect and remove the spyware? No single
>> product gets them all, and you almost always need to run a combination
>> of several different programs to fully clean up a computer.
>> Good luck
>> Ron Martell Duncan B.C. Canada
>> Microsoft MVP
>> On-Line Help Computer Service
http://onlinehelp.bc.ca
>> "The reason computer chips are so small is computers don't eat much."
> I used TrendMicro, Spybot S&D, Adaware, CA's firewall.
> It took 2 hours for TM to run and it found and deleted 5 viruses, Spybot
> found 93 on the first pass and 23 on the second pass (from Safe Mode)
> Adaware found 210 problems. (my friend had absolutely no security so I was
> surprised it wasn't worse)
> Startup listed Kazaa, Gator, a couple of TFTP files, and some other stuff
> that looked suspicious to me so I turned them off, but they showed up
> turned
> on again after I rebooted.
> I may have checked Normal Startup instead of Selective before I rebooted -
> would that have turned everything back on again?
