One of my mum's friends had one of those HP Pavilion Media Center PCs where the graphics card started acting up to the point where would couldn't boot into Windows whatever option we tried. We were certain it was the dodgy X600 graphics card as there were odd patterns appearing on the screen at startup and the memory was fine when tested in another computer.
I used the F10 automated system recovery option on the computer which reinstalled Media Center from scratch, including HP's graffitti and applications, but because of the dodgy graphics card I was unable to complete the final part of the installation - I even got a blue screen explicitly saying it was the video card at fault.
Following advice from a retailer, we purchased a new graphics card, X1600PRO, installed it, and the last part of the recovery completed. I was able to boot into Windows without any problems, and then Windows decided to label the new graphics card as "Video Adapter" and "Video Adapter (VGA Compatible)" with question marks in the device manager. Despite this I tried to go ahead and install the supplied graphics card CD but the installation application wouldn't install, claiming that it could not find the device, and if the device is present I should try installing it as a Standard Video Adapter and then running the application.
So I took its advice and tried to install these devices as "standard adapters" but the option wasn't even there, even when I chose to search for all hardware and search on Windows Update!!! Only option I have is to chose a list of Graphics adapters that HP use or to get Windows to read in drivers for this particular card from the driver CD supplied.
Where do I go from here!?! Damn HP and their customized installs!!
PC Spec
P4 3ghz
1GB RAM
PCI-e graphics card
Audigy 2 Soundcard (OEM version)
DVD & DVD-RW Drives
TV Tuner Card
Wifi
200GB Hard Disk
PC Spec
P4 3ghz
1GB RAM
PCI-e graphics card
DVD & DVD-RW Drives
TV Tuner Card
Wifi
200GB Hard Disk
