Archived from groups: microsoft.public.win2000.group_policy (
More info?)
No there isn't anything included in that that seems to help. It was run as
the domain administrator having the issue correct?
Are you able to get into control panel in general, including others?
Check the local Administrators group on the machine for the Domain Admins
group. It should be there by default, as it is added when the computer is
joined to the domain.
You could even use regmon and filemon from www.sysinternals.com to track
what is occuring when you do that. then look for any access denied that
occur.
Gary Mudgett, MCSE, MCSA
Windows 2000/2003 Directory Services
When responding to posts, please "Reply to Group" via
your newsreader so that others may learn and benefit
from your issue.
This posting is provided "AS IS" with no warranties, and confers no rights.
"Phil" <anon@hotmail> wrote in message
news:uD$fo5zbEHA.1004@TK2MSFTNGP11.phx.gbl...
> This is what I get, though can't see anything that helps:
> The following settings were applied from: Local Group Policy
> KeyName: Software\Policies\Microsoft\SystemCertificates\EFS
> ValueName: EFSBlob
> ValueType: REG_BINARY
> Value: Binary data. Use the /S switch to display.
> KeyName:
Software\Policies\Microsoft\SystemCertificates\EFS\Certificates\606DE1E5223B
> 9F7B1C40DD8677E63B7587F15345
> ValueName: Blob
> KeyName:
> Software\Policies\Microsoft\SystemCertificates\EFS\CRLs
> ValueName:
> ValueType: REG_NONE
> Value: This key contains no values
> KeyName:
> Software\Policies\Microsoft\SystemCertificates\EFS\CTLs
> ValueName:
> ValueType: REG_NONE
> The following settings were applied from: Default Domain Policy
> ValueName: EFSBlob
> KeyName:
Software\Policies\Microsoft\SystemCertificates\EFS\Certificates\A7462A814997
> AEC3B0DA9D4F14E8BE4C6EB1A6AF
> ValueName: Blob
> KeyName:
> ValueName:
> ValueType: REG_NONE
> KeyName:
> ValueName:
> ValueType: REG_NONE
> KeyName: Software\Policies\Microsoft\Windows\System
> ValueName: GroupPolicyRefreshTime
> ValueType: REG_DWORD
> Value: 0x0000003c
> ValueName: GroupPolicyRefreshTimeOffset
> Value: 0x0000001e
> ValueName: GroupPolicyRefreshTimeDC
> Value: 0x0000003c
> ValueName: GroupPolicyRefreshTimeOffsetDC
> Value: 0x0000001e
> KeyName: Software\Policies\Microsoft\Windows\WindowsUpdate
> ValueName: WUServer
> ValueType: REG_SZ
> Value:
http://WUServer
> ValueName: WUStatusServer
> ValueType: REG_SZ
> Value:
http://WUServer
> KeyName:
Software\Policies\Microsoft\Windows\WindowsUpdate\AU
> ValueName: NoAutoRebootWithLoggedOnUsers
> Value: 0x00000001
> KeyName:
> ValueName: UseWUServer
> Value: 0x00000001
> KeyName:
> ValueName: NoAutoUpdate
> Value: 0x00000000
> KeyName:
> ValueName: AUOptions
> Value: 0x00000004
> KeyName:
> ValueName: ScheduledInstallDay
> Value: 0x00000005
> KeyName:
> ValueName: ScheduledInstallTime
> Value: 0x00000006
> KeyName:
> ValueName: RescheduleWaitTime
> Value: 0x00000002
> The following settings were applied from: Company Computer
> [Defaults]
> KeyName:
> Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
> ValueName: NoWelcomeScreen
> Value: 0x00000001
> KeyName:
> Software\Microsoft\Windows\CurrentVersion\Policies\System
> ValueName: LogonType
> Value: 0x00000000
> ValueName: UserPolicyMode
> Value: 0x00000001
> NT\CurrentVersion\Winlogon
> ValueName: SyncForegroundPolicy
> Value: 0x00000001
NT\SystemRestore
> ValueName: DisableSR
> Value: 0x00000000
NT\SystemRestore
> ValueName: DisableConfig
> Value: 0x00000000
> The computer received "Scripts" settings from these GPOs:
> Revision Number: 126
> Unique Name: {31B2F340-016D-11D2-945F-00C04FB984F9}
> Domain Name: domain.com
> Linked to: Domain (DC=companydomain,DC=com)
> Company Computer [Defaults]
> Revision Number: 125
> Unique Name: {7CB34FD7-66FE-4C87-A719-78CF0BD6F399}
> Linked to: Organizational Unit (OU=Company
> Computers,DC=casting
> sdev,DC=com)
> Company Computer [Windows 2000]
> Revision Number: 27
> Unique Name: {47FFCCAE-B68E-42AB-95E5-7E64F971AD56}
> Linked to: Organizational Unit (OU=Windows
> 2000,OU=Company Comp
> uters,DC=companydomain,DC=com)
> Company Computer [Windows 2000] [Desktops]
> Revision Number: 5
> Unique Name: {E0038A40-90F4-46FC-A067-0F8B11F7CC75}
(OU=Desktops,OU=Windows
> 2000,OU=Company Computers,DC=companydomain,DC=com)
> Startup scripts specified in: Default Domain Policy
> localadmin.vbs cast1ngs968
> Startup scripts specified in: Company Computer [Defaults]
> UTILINSTALL.BAT
> CompanyTheme.bat
> VPLOGON.BAT
> Startup scripts specified in: Company Computer [Windows 2000]
> LoginScreen2000.bat
> [Desktops]
> power2000.bat
> The computer received "Security" settings from these GPOs:
> Local Group Policy
> Revision Number: 3
> Unique Name: Local Group Policy
> Domain Name:
> Linked to: Local computer
> Domain Name: DOMAIN.COM
> Run the Security Configuration Editor for more information.
> The computer received "EFS recovery" settings from these GPOs:
> Local Group Policy
> Revision Number: 3
> Domain Name:
> Additional information is not available for this type of policy
> setting.
> The computer received "Application Management" settings from these GPOs:
> Revision Number: 124
> Revision Number: 27
> Revision Number: 5
> "Gary Mudgett [MSFT]" <garymu@online.microsoft.com> wrote in message
> news:eUIeC9ybEHA.556@tk2msftngp13.phx.gbl...
> > Does sound like a domain level policy is getting applied to the domain
> > Administrator account.
> > Can you run "gpresult /v" and look at that output?
> > from your issue.
> rights.
> > news:uJVqPxvbEHA.3988@tk2msftngp13.phx.gbl...
> > > Hiya guys
> > > Just a small problem really, I have been away for a while, and during
> this
> > > time we have had some agency guys about looking after things.
> > > However, now that I am back I have noticed a small problem that I
can't
> > sort
> > > out.
> > > On our W2K clients (though not with our WinXP clients) when an domain
> > admin
> > > user 'right-clicks' "My Network Places" and clicks properties, a
warning
> > box
> > > pops up saying that they don't have permission to open the "Network &
> > > Dial-up Connections folder". The only way to get in there is to login
in
> > as
> > > the local workstation admin user.
> > > Any one have any ideas? I'm guessing one of the agency guys fiddled
with
> > > something in the GP, but damn if I can find it!
> > > Any help or tips would be great
> > > Cheers
> > > Phil
