Got it booted up and have two problems:
1. Is it suppose to say something to the effect on the bootup screen that memory will operate as single channel? I have two sticks of DDR2-800 memory and it is recognizing the full amount (1 gig, 2 x 512 sticks).
2. For some reason the CPU fan does not work. I have a Tuniq 120 which uses a three pin connector. I plugged it into the correct right side of the CPU fan. I noticed there are some bios setups related to the CPU fan. I tried selecting "Disable" which runs the fan at full speed but that still didn't work. Am I missing something?
THANKS!
THANKS!
