Your issues may (or may not) be related to your PSU. For the direct answer - is the antec good - yes, for your build 400W is pleanty - 430, 450W is fine as well. I would not go any higher unless you are slowly building out a new system from any new purchases.
In addition to MEMTEST, and PRIME - you need to check out your thermal situation, clean out any dust, and make sure you have a good amount of airflow. Then check your temps, and make sure they are 'normal'.
One thing you may want to try - is to underclock your video card. I had to do this to my 7600GT to figure out if it was failing as a result of a thermal condition. The GPU wasn't getting too hot, but other components on the card were - and that caused system failure. Download the coolbits regestry hack, and slide your GPU and Memory frequencies about halfway down the scale. Test in a situation that would normally cause a failure. If it fails, then the problem is likely somewhere else. If it doesn't fail (and this was the ONLY change you made) then the problem is with your video card - or less likely with the power that is being given to your video card.
Give it a shot - and let us know what you find. Give us your temps and other figures.
Also - if you could give a full list of specs - PSU, Case, Ect....that might help as well.
Cheers.
