Archived from groups: microsoft.public.windowsxp.basics (More info?)
Hi all,
I recently upgraded my operating system from Windows 98 to Windows XP Home
Edition. One strange problem I've had since the upgrade is that I now can't
get any sound from my Roland SC8850 sound module through my PC monitors. I
hear all other system sounds ok & CDs & MP3s play fine but nothing from my
SC8850.
I've had the SC8850's main L & R audio outputs connected to my PC's Line In
via an rca-to-small stereo jack-cable & this setup has worked fine until
now. The headphones output on the SC8850 seems to work fine but I now can't
hear any sound fgrom the SC8850 thru my montiors. Any ideas on how to
rectify this situation?
Have you checked the advanced volume control to see if any of the controls
are either muted or the slider all the way down? I have seen mine changed
following a major upgrade. If the speaker icon is in the tray, right click
on it and choose Volume Control. If not open the Control Panel, Sounds
Speech and Audio Devices, Advanced Audio Controls. You can check the box to
show the speaker item while you are at it (if desired). If everything there
looks OK, check the Sounds and Audio Devices Properties box (right click on
Sounds and Audio Devices). Just some thoughts in case you had not checked
these.
Colin Barnhorst [MVP Windows - Virtual Machine]
(Reply to the group only unless otherwise requested)
"Kingy75" <kingy75@tpg.com.au> wrote in message
news:uoYAKWzDFHA.1564@TK2MSFTNGP09.phx.gbl...
> Hi all,
> can't get any sound from my Roland SC8850 sound module through my PC
> monitors. I hear all other system sounds ok & CDs & MP3s play fine but
> nothing from my SC8850.
> In via an rca-to-small stereo jack-cable & this setup has worked fine
> until now. The headphones output on the SC8850 seems to work fine but I
> now can't hear any sound fgrom the SC8850 thru my montiors. Any ideas on
> how to rectify this situation?
> Any advice is greatly appreciated, thanks.
> Chris
Ah ha! I have fixed the problem, the Line In was muted somewhere in the
chain. Thanks for your reply.
Cheers,
Chris
"Colin Barnhorst" <colinbarharst(nojunk)@msn.com> wrote in message
news:eVbtkK0DFHA.2540@TK2MSFTNGP09.phx.gbl...
> click on it and choose Volume Control. If not open the Control Panel,
> Sounds Speech and Audio Devices, Advanced Audio Controls. You can check
> the box to show the speaker item while you are at it (if desired). If
> everything there looks OK, check the Sounds and Audio Devices Properties
> box (right click on Sounds and Audio Devices). Just some thoughts in case
> you had not checked these.
>> Hi all,
>> Home Edition. One strange problem I've had since the upgrade is that I
>> now can't get any sound from my Roland SC8850 sound module through my PC
>> Chris
You're welcome.
news8sT$J9DFHA.3416@TK2MSFTNGP09.phx.gbl...
> Cheers,
> Chris
>> controls are either muted or the slider all the way down? I have seen
>> mine changed following a major upgrade. If the speaker icon is in the
>> tray, right click on it and choose Volume Control. If not open the
>> Control Panel, Sounds Speech and Audio Devices, Advanced Audio Controls.
>> You can check the box to show the speaker item while you are at it (if
>> desired). If everything there looks OK, check the Sounds and Audio
>> Devices Properties box (right click on Sounds and Audio Devices). Just
>> some thoughts in case you had not checked these.
>>> Hi all,
>>> Chris
