I have had my comp running at 3.6 ghz 1.46v,180 fsb, ddr2 720, for a while now. I ran Prime 95 over night with no errors and have had no problems with my system. Last night I decided that i was going to tighten up the timings on my ram. It was running at 4-4-4-10 at 1.8v(ran memtest86+ for 8 hrs no errors), I started by setting the volts to 2.2, and the 3-4-4-10 and then booted into windows. then went to 3-3-4-10 and booted into windows. went to 3-3-3-10 booted into windows. then went to 3-3-3-8 booted into windows. This is where all the fun beginns to happen, I decided to run memtest86+ left it for about 15 to 20 minutes, when i looked at the screen i noticed 2 errors. I then tried to esc out of memtest and it wouldnt respond so i pushed the power button in and turned off the comp. Had to clear the cmos to get the computer to boot so i went into bios and had to reset every setting time, date, boot sequence. When i went to save and restart the comp it powered all the way down and wont power up at all. The board is getting power because the debug light is on and reads 0.0.
components : Pentium 805D, Zalman 9500, Abit AW9D max with the uguru front panel, Patriot ddr2 667 ram, sapphire x850xt, 450 watt psu that came with my raid max case.
http://www.newegg.com/Product/Product.asp?Item=N82E16811156180
Thanks in advanced for the help.
