OK, I need some good advice about building/buying a new system. I have a person that may be willing to buy my current rig and if I do that, I need to immediately build/buy a new one. I want a pretty high-powered rig, but need to keep a budget. I will show what I have right now and note what my goals are. I have not kept up on the newest stuff, so thats why I need help. I also do not hardcore overclock, but will tweak my system up a little bit. I do a lot of high powered programming and a lot of gaming, so I need a powerful system.
MB: DFI NF4 SLI-DR
CPU: AMD 64 x2 4400+ (thermalright xp90 cooler, arctic silver compound)
MEM: OCZ Gold EL VX DDR500 4x512 (set 3.2v)
VID: Asus Nvidia 7800GTX
HD: (2) SATA II Hitachi 180GB (RAID 0)
PSU: OCZ GamerXtreme 600w
SOUND: Audigy 2 ZS Gamer
CASE: Antec P180 (4x120mm panaflo fans, 2xmb fans, 90mm vid card blower, dust filters, etc)
Ok, so lemme break down my opinion/goals of each major piece:
CPU: I want AMD. I do not know if I should be going for an AM2 X2, AM2 FX, or some sort of opteron. I want speed and stability. I like dual-core. What do you suggest? I want a speed of what I have or faster. Also, is it a much better option to go with the new conroe core2duo?
MB: I have DFI now and although I had to replace it, I do like the board. I want something thats stable and reliable, but fast and flexible. I know this will depend on the CPU/MEM also.
MEM: I have the OCZ Gold now and think its great. I have it at 3.3v since its the vx series. I have heard that high priced memory is not worth it. I do not know for sure, but I want something that will not overheat and will run at high performance. Also, I need NO less than 4GB. 4GB is a requirement.
VID: My 7800GTX Asus is pretty good, but I want an upgrade. Should I do SLI or not? I do alot of video stuff and tons of gaming. I thought about like 1 8800GTX or like (2)7950's. I want a setup that is reliable and doesnt have problems. For example, I run RAID0 with my SATAII's and I have bootup problems from time to time. I dont want problems from SLI if it is known to be an issue. I want a brand that is reliable and wont burn up also. I got Asus on my last 2 cards because it was reliable. I am open to anything.
HD: I want high-speed and high storage. I have (2) Hitachi 160GB in RAID0 now, but like I said I have boot problems form time to time. Sometimes it does not find the drives or it blue-screens for some reason. It doesnt happen often but it has happened 2-3 times. I want something reliable and fast. I would say that I want like maybe 300GB+ for storage total. I want the fastest SATA, which I think is SATAII. Should I do RAID0, RAID1, or no RAID at all? I am not sure if RAID0 makes that much difference on a desktop. I want to be able to backup my data, so I need either a RAID 1, or at least 2 drives so I can manually backup data to a second drive.
PSU: One thing I have learned is that PSU is everything. I want something that will never give me worries to run my systems. Enough power and stability is what I want.
SOUND: I dont really know much about sound. I want something that sounds decent, but I dont need the highest end $300 card or whatever.
CASE: I really like the Antec P180. It has room and stays cool. I am also debating if I should go liquid cool or stay fans. I want my system to run cool so if I decide to OC, it will be fine. I am VERY nervous about liquid because I do NOT want to fool with a bunch of maintenance. I want to buy/build it once and do nothing but keep it clean and run it. I would consider liquid, but I am nervous about maintenance and the potential of something breaking and leaking.
Now I know thats quite a list, but I need some help. If I can buy a custom system built, thats great. I looked at www.cyberpowerinc.com and they are good, but have limited choices on hardware. I can build it myself as well. I know computers, but I do not like constantly having to work on it.
Anyway, please give me some good current advice. I have a ballpark budget of about $2000. I do NOT need a monitor or speakers.
Any help is appreciated.
MB: DFI NF4 SLI-DR
