Long time reader of THG, first time poster.
I was playing WoW Burning Crusade and noticed my computer would freeze after a few hours of play. It would do so with a checkered graphic pattern and completely lock up the computer. Only way to reset was by the switch.
Yesterday that turned into my computer unable to stay on for more then 10 seconds. At first I figured it was a heat issue so I cleaned out all the fans. All of them are working. I then let the comp cool over night for approx. 9 hours. Tried to turn it on this morning and same thing. I could barely get to the splash screen of the MoBo for POST before the thing turned off.
So I ask: Is this a CPU issue? Or is it more likely a bad power supply? Or something else completely?
Thanks
Thanks
