Sign-in / Sign-up
Cable Management: Use EZ-Sleeve or Regular sleeving
  • Homebuilt
  • Management
  • Cable
  • Systems
Last response: in Systems
January 21, 2007 7:27:34 PM
Hey guys, I've been trying to decide which would be better. FrozenCPU has the EZ-sleeve stuff that they claim is super easy. I'm just wondering if it is good at all, or if you are better off using the standard stuff for a more long term solution.
Anyone here ever used the "EZ-sleeve"? And for those of you that have used the regular sleeving, is there a kit you would recommend? Any advice is greatly appreciated!!
More about : cable management sleeve regular sleeving
January 21, 2007 8:29:01 PM
I would maybe use EzySleeve outside the PC, but never inside. Stick to cable ties. :D
January 21, 2007 8:37:39 PM
Outside? How would you use it outside? I want to sleeve the cables on the inside with something. Are you saying to not sleeve, and just use cable ties for everything?
