Well its almost Tax Time and everyone wants a new system built and i need some advice..One Mushkin product seems to be perfect..
model 991518 512MB DDR Dram its timing is 3-3-3-9
I need to know if it will compatible with the config I have so far
Intel Pentium D 930 Presler 3.0GHz 2 x 2MB L2 Cache LGA 775 Dual Core Processor
http://www.newegg.com/Product/Product.asp?Item=N82E16819116238
mushkin 512MB 240-Pin DDR2 SDRAM DDR2 533 (PC2 4200)
http://www.newegg.com/Product/Product.asp?Item=N82E16820146095
ECS PA1 MVP (2.0) LGA 775 ATI Radeon Xpress 200 CrossFire ATX Intel Motherboard
http://www.newegg.com/Product/Product.asp?Item=N82E16813135218
HIS Hightech H165PRQ512N-R Radeon X1650PRO 512MB 128-bit GDDR2 PCI Express x16 IceQ Video Card Times 2
http://www.newegg.com/Product/Product.asp?Item=N82E16814161039
ePOWER ZU-650W ATX12V Version 2.0 / EPS12V 650W Power Supply 115/230 V cUL, CE, FCC, TUV
http://www.newegg.com/Product/Product.asp?Item=N82E16817101013
Western Digital Raptor WD740ADFD 74GB 10,000 RPM 16MB Cache Serial ATA150 Hard Drive
http://www.newegg.com/Product/Product.asp?Item=N82E16822136033
I have Question about supported ram speeds ..for example on a 478 motherboard with Celeron 2.4 with a 533FSB ..PC3200 ram (400mhz)..will be ran at 2700 speed (333mhz) but with a Pentium4 3.2 E 800mhz 400mhz ram can run at its normal speed...
also...will that mobo @ processor support that ram at all.. 533 3-3-3-9 over the 667 at 5-5-5-15 if i could get 667 with with 4-4-4-12 for the same price in a brand I feel i can depend on I would not worry about the latency but I feel the difference is substantial...I know that the 667 would prolly be better for file conversions and map loading but I am more worried about actual in Game performance..where there are fast changes..games like eq2 and similar games....and some FPS's Like 2142 and PlanetSide.. will that dif in latency on slower RAM Help more than the speed of the the 667 RAM???
With my config above what limits do I have on RAM speed..
Do I have to have a CPU with 1066 to use 667mhz ram at its actual speed ect
Update: Mushkin 667 3-3-3-10 model number 991509
http://www.newegg.com/Product/Product.asp?Item=N82E16820146090
Will this Ram work at its full potential with this system...???
