External harddrive should it be power off or not
Hi everyone, just a simple question. Do you recommend to power off an external harddrive every time you power off the pc ?
1 answer Last reply
More about external harddrive power
  1. depends on how you have the external optimized.
    if its optimized for quick removal then no.
    if its optimized for speed then it would be a good idea. although ive had one for several years now and ive never had a problem with it. just dont hard boot :wink:
Power External Hard Drive Storage
