Tom's Hardware > Forum > Graphic & Displays > Nvidia > 8800GTX's in SLI... odd problem
Forum Graphic & Displays : Nvidia - 8800GTX's in SLI... odd problem
I have two watercooled BFG 8800GTX's in SLI.
I found that I have graphics corruption and other issues with the sli connector bridging the 2 sli connectors closest to the middle of the cards, but if move it to the other two SLI connectors (nearest the cards back panels) it seems to work OK.
There was nothing in the documentation about which connectors to use, and why there are two on the 8800GTX.
I'm concerned that one or both of my cards may be faulty and I may want to use the other connectors later for physics or even another GPU.
To anyone else with two 8800GTX's in SLI: Which SLI connector are you using and do you see the same thing?
Thanks guys.
Sponsored Links
There are 1051 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
