Greetings.
I've built a simple, basic system from parts I had lying around. A while back I purchased a DFI AZ-30-TC (YES, I know it's ancient! lol). Never really had a use for it, until my usual PC caught a virus (shame on me).
So after reformatting the primary dos partition and and several un-successful attempts to install windows 98 (it kept hanging on the "Insert diskette in drive b:" error), I found an old system with win98 already installed.
I decided to try and run a new system off this other 98 HD, using my old HD in slave mode. While I was at it, I remembered I had this DFI board that hadn't even been out of the static bag. I also bought this Athlon XP 2600+ Thorobred off this local guy on MySpace. I'll admit, the CPU looked a little cruddy. There was thermal paste all over the top of the CPU. But I decided to give it ago anyways.
Anyway, I get this thing together. I'm using a case from a system I purchased back in 1998, with a Pentium II 400 MHz, so I'm guessing that I got the front panel connections right. The power supply is a rarely used 300 Watt Antec, so it's not junk. The case & PSU were used successfully with a different mobo/CPU in the past.
So here's the system specs
DFI AZ30-TL with on-board LAN, Rev. A Set at default FSB of 100 MHz
WD 13 GB HDD (MS)
MAXTOR 120 GB HDD (SL)
Antec 300 W PSU
Apacer DDR 256MB, PC2300
So I power it up- I plug it in with the PSU switch in the OFF position. Then I switch the PSU switch to ON. The CPU fan starts...and then just stops. The PSU doesn't run. No LEDs come on. It just sits there. So I turn the switch off, and then I hear the faint chirp noise from the power supply, like capacitor discharging.
I made sure all my cards were seated, and all my wires were connected. Everything looks ok. The ONLY thing I can figure is the CPU. The CPU fan lead is plugged into the fan power on the board.
At THIS point, rather than risk messing up my only other respectable CPU in my possession by testing it in the new mobo, I'm tempted to just purchase a new system. Any other troubleshooting suggestions before I hop on to newegg.com?
WD 13 GB HDD (MS)
Antec 300 W PSU
