Using Partiton Magic 8.0
Forum Windows XP : Windows XP General Discussion - Using Partiton Magic 8.0
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I wanted to resize a partition. I installed PM 8.0. It starts to run
then stalls. If I start PM from the its rescue disks it tells me it
can't run because disk management software is not running. Naturally
I've already tried reinstalling, uninstalling/reinstalling PM etc.
Is this disk management software something in XP that should be
running? If it is, any ideas how to turn it on?
PM website, help, MS KB, and Google haven't produced any answers for
me.
TIA
DFB
"When a legislature undertakes to proscribe the exercise of a citizen's
constitutional rights it acts lawlessly and the citizen can take matters into
his own hands and proceed on the basis that such a law is no law at all."
- Justice William O. Douglas
Sponsored Links
Well, getting help from Symantec for their products is typical as you describe. Try uninstlaling and reinstall PM8 and see what happens.
"MisterSkippy" <MisterSkippy@optonline.net> wrote in message news:9k1v011opmk39usof9dlbo8ia9ff5lktg1@4ax.com...
> me.
> TIA
> DFB
Reply to Tom
Disk management software is supplied by the manufacturer of the hard drive.
It is also known as a drive overlay. It is useful on older computers that
can not handle the large size hard drives due to hardware/bios limitations
(many people use it to set up a new hard drive). The problem is, it
interferes with almost everything. Even Windows XP has trouble with it at
times.
Regards,
Richard Urban
aka Crusty (-: Old B@stard :-)
If you knew as much as you think you know,
You would realize that you don't know what you thought you knew!
> me.
> TIA
> DFB
> into
Reply to Anonymous
Thanks for the speedy reply.
Have done that a few times trying different drives.
No luck so far.
Reply to Anonymous
On Sun, 13 Feb 2005 12:48:51 -0500, "Crusty \(-: Old B@stard :-\)"
>times.
Thanks for the speedy reply. The comp is new, no overlay SW. Master
HD (80 gig) partitioned 10, 20 and 50. Slave is another 80 from old
comp.
Reply to Anonymous
Some chap on the following link had a problem similar to yours, his solution
may help you?
http://forums.betarun.net/showthread-19.html
Regards
Joe Steele
Reply to Anonymous
Does the Error Message have a number?
Hope this helps.
Gerry
FCA
Using invalid email address
Stourport, Worcs, England
Enquire, plan and execute.
Please tell the newsgroup how any
suggested solution worked for you.
http://dts-l.org/goodpost.htm
news:evav01147vbn5t6bq3f4n35qpr2nkui51b@4ax.com...
>>drive.
>>that
>>limitations
>>at
>>times.
> comp.
> citizen's
> matters into
> all."
Reply to Anonymous
- 0 +
Try going here www.terabyteunlimited.com, and download/install BooIt NG. It is a fully functional 30 day trial, and will do everything PM does, with more ease. Resize the drive in question, then uninstall BootIt, but I think it is a great deal for $35.
> me.
> TIA
> DFB
Reply to Tom
>> me.
>> TIA
>> DFB
Thanks for the reference. For some reason the program claims it can't
resize the problem partition. Before I muck things up worse, can you
give me the short course in how to get rid of the program?
Do I just delete the entries it put in the root drive? The terrabyte
website is short on answers.
Reply to Anonymous
On Sun, 13 Feb 2005 19:26:31 -0500, MisterSkippy
>>> me.
>>> TIA
>>> DFB
My bad. I found the instructions to uninstall. All gone now.
Again, thanks for the efforts.
Regards
DFB
Reply to Anonymous
Partitioning is only done for legacy users. It is one of the biggest
problems amoung our Computer Club's users. The vendors glorify it at our
General meetings, and our in-home trouble shooters spend hours fixing the
problems. If you want to boot different operating systems, OK. Otherwise,
Windows XP can get along without it.
news:svsv01tageu75esimpf51t4n5j4j2o4cgi@4ax.com...
>>>> me.
>>>> TIA
>>>> DFB
> Regards
> DFB
> into
Reply to Anonymous
I agree. Besides, you can run legacy operating systems with Virtual PC 2004
and not have to mess with multibooting.
Colin Barnhorst [MVP Windows - Virtual Machine]
(Reply to the group only unless otherwise requested)
"Chuck Davis" <newsgroup at anthemwebs dot com> wrote in message
news:urtB6tjEFHA.960@TK2MSFTNGP09.phx.gbl...
>>>>> me.
>>>>> TIA
>>>>> DFB
>> Regards
>> DFB
>> into
Reply to Anonymous
- 0 +
For the simple minded, yes XP can manage a single large volume disk.
If one wants to manage and prepare for disaster recovery using only one hard
drive, then partitioning is essential.
Let me explain: once you have spent hours and hours configuring your PC with
XP and the dozen or so applications and / or games: then it is most
advantages to use an application such as Ghost to IMAGE the drive. The image
file can be used to recreate the hard drive in case of a catastrophe.
One cannot take an image file and 'restore' it to the same hard drive or
partition on which it is located. Thus partitioning the Hard Drive is VERY
BENEFICIAL andmost useful.
To restore the drive from the image file may take up to one hour only as
opposed to a day or two needed for reinstalling XP and the dozen or so
applications and then copying all one's personal data back to the C Drive off
CDs.
> >>>>> me.
> >>>>> TIA
> >>>>> DFB
> >> Regards
> >> DFB
> >> into
Reply to bar
In news:0F6ECBB7-2907-48CA-9E96-E3C1B6172767@microsoft.com,
BAR <BAR@discussions.microsoft.com> typed:
> disk.
> only
> one hard drive, then partitioning is essential.
> your
> PC with XP and the dozen or so applications and / or games:
> then it
> is most advantages to use an application such as Ghost to IMAGE
> the
> drive. The image file can be used to recreate the hard drive
> in case
> of a catastrophe.
> drive
> or partition on which it is located. Thus partitioning the
> Hard
> Drive is VERY BENEFICIAL andmost useful.
If you are suggesting using an image file to a second partition
for backup, I would strongly urge you to reconsider that backup
startegy. I don't recommend backup to a second partition because
it leaves you susceptible to simultaneous loss of the original
and backup to many of the most common dangers: head crashes,
severe power glitches, nearby lightning strikes, virus attacks,
even theft of the computer.
In my view, secure backup needs to be on removable media, and not
kept in the computer. For really secure backup (needed, for
example, if the life of your business depends on your data) you
should have multiple generations of backup, and at least one of
those generations should be stored off-site.
My computer isn't used for business, but my personal backup
scheme uses two identical removable hard drives, which fit into a
sleeve installed in the computer. I alternate between the two,
and use Drive Image to make a complete copy of the primary drive.
Ken Blake - Microsoft MVP Windows: Shell/User
Please reply to the newsgroup
Reply to Anonymous
Salut/Hi Crusty (-: Old B@stard :-),
le/on Sun, 13 Feb 2005 15:49:36 -0500, tu disais/you said:-
>Disk management software, which you said is causing problems, is a type of
>disk overlay program. Different manufacturers call it by different names.
>Three weeks ago I installed a new 160 gig hard drive in a clients computer.
>I figured I would use the software that came with the WD drive.
WD????
In UK speak that's War Department.
In computer speak... err. Could you translate into something human readable
please.
Word document?
Wonderful Disk?
All the Best
Ian Hoare
http://www.souvigne.com
mailbox full to avoid spam. try me at website
Reply to Anonymous
Western Digital
"Ian Hoare" <ianhoare@angelfire.com> wrote in message
news:h7i111hjnce0or9lrdqsghoju250fqcb21@4ax.com...
>>computer.
> WD????
> readable
> please.
> Word document?
> Wonderful Disk?
> All the Best
> Ian Hoare
Reply to Anonymous
In news:h7i111hjnce0or9lrdqsghoju250fqcb21@4ax.com,
Ian Hoare <ianhoare@angelfire.com> typed:
>> is a
>> type of disk overlay program. Different manufacturers call it
>> by
>> different names.
>> clients
>> computer. I figured I would use the software that came with
>> the WD
>> drive.
> WD????
> human
> readable please.
he means Western Digital, a well-known manufacturer of hard
drives.
Reply to Anonymous
Salut/Hi Ken Blake,
le/on Mon, 14 Feb 2005 08:36:13 -0700, tu disais/you said:-
>> disk.
>> only one hard drive, then partitioning is essential.
Couldn't agree more. In fact, I can think of very few catastrophes which
would render one partition unavailable without doing the same to the entire
disk.
Agreed. Which is why I made the idiotic mistake of buying the 2 Gig Iomega
SCSI Jaz drive. That managed to eat 3 removable drives and render them
unusable before I finally gave up on it. I now have a little Freecom USB2 30
gig drive.
> For really secure backup (needed, for example, if the life of your business depends on your data) you
>should have multiple generations of backup, and at least one of those generations should be stored off-site.
Agreed again, though Bruce might well call an emergency off site backup copy
of software "Piracy" (GD&R Yes I know there's a difference between "data"
and "applications", but quite a number of my applications were downloaded).
All the Best
Ian Hoare
Reply to Anonymous
Salut/Hi Ken Blake,
le/on Mon, 14 Feb 2005 13:25:13 -0700, tu disais/you said:-
>>> clients computer. I figured I would use the software that came with
>>> the WD drive.
>> WD????
>> human readable please.
>drives.
Thanks very much Ken. Although I've heard (obviously) of them, their name
simply didn't come to mind, although I was racking what's left of my brain.
All the Best
Ian Hoare
Reply to Anonymous
It is not piracy since the backup cannot be run in its backup form.
news:ulj111dpniinaptbh7u2f9ceu41knmi97e@4ax.com...
> Salut/Hi Ken Blake,
>>> disk.
> entire
> disk.
> 30
> gig drive.
> copy
> downloaded).
> All the Best
> Ian Hoare
Reply to Anonymous
In news:ft4211lah4dvjour9bd1v91fq7080u5q3e@4ax.com,
> Salut/Hi Ken Blake,
>>> WD????
>> drives.
> their
> name simply didn't come to mind, although I was racking what's
> left
> of my brain.
You're welcome, Ian.
Reply to Anonymous
In news:ePoRg3tEFHA.628@TK2MSFTNGP15.phx.gbl,
Colin Barnhorst <colinbarharst(nojunk)@msn.com> typed:
> form.
It depends on what form that backup drive is. It *could* be a
complete clone of the original drive.
But regardless of what form it's in, it's not piracy because what
I recommended is not installing it on a second computer or even
on a second drive or partition on the same computer; it's making
a copy on a drive not installed in any computer.
>> Salut/Hi Ken Blake,
>>>> volume
>>>> disk.
>>>> using
>>> partition
>>> backup
>>> because
>>> original
>>> attacks,
>> catastrophes
>> which would render one partition unavailable without doing the
>> same
>> to the entire
>> disk.
>>> not
>> 2 Gig
>> Iomega SCSI Jaz drive. That managed to eat 3 removable drives
>> and
>> render them unusable before I finally gave up on it. I now
>> have a
>> gig drive.
>>> your
>>> of
>> site
>> backup copy
>> between
>> "data" and "applications", but quite a number of my
>> applications were
>> downloaded).
>> All the Best
>> Ian Hoare
Reply to Anonymous
>>disk.
>>only
>>your
>>then it
>>the
>>in case
>>of a catastrophe.
>>drive
>>Hard
I echo what Ken says above. For those who have followed my trials
and woes in past months, I can say that, with good help in this
group (and a few barbs and arrows), I have a working procedure that
involves Partition Magic 8 in conjunction with Drive Image 7.
I have two hard drives. Both need only be in the computer, as
a Master and a Slave, periodically when I make a drive image of my
Master drive, on the Slave drive. Should anything go bad with the
Master, I use Drive Image 7 to restore to the master, what it
contained when the drive image was made.
Partition Magic, in this simplified system, is almost superfluous,
except that it is a handy tool for increasing and decreasing the sizes
of partitions.
William B. Lurie
Reply to Anonymous
Salut/Hi "Colin Barnhorst" <colinbarharst(nojunk)@msn.com>,
le/on Mon, 14 Feb 2005 14:40:58 -0700, tu disais/you said:-
With respect, Colin, BAR's comments (which we could have preserved had you
not top posted and then used a sig delimiter which makes properly configured
newsreaders remove anything below the --) talked about using - I quote:-
Such an image file could well be run.
I'm not disputing for the sake of it, but I'd have hoped you might have
recognised that I was very gently mocking Bruce Chambers' somewhat eccentric
view of life. Sadly it seems that I was mistaken. You do understand the
abbreviation "GD&R" don't you? Because if you did, the comment was obviously
not to be taken seriously.
All the Best
Ian Hoare
Reply to Anonymous
- 0 +
<billurie@nospam.org> wrote in message
news:OyTxIXuEFHA.2876@TK2MSFTNGP12.phx.gbl...
>>>PC with XP and the dozen or so applications and / or games: then it
>>>is most advantages to use an application such as Ghost to IMAGE the
>>>drive. The image file can be used to recreate the hard drive in case
>>>of a catastrophe.
>>>or partition on which it is located. Thus partitioning the Hard
>> If you are suggesting using an image file to a second partition for
>> backup, I would strongly urge you to reconsider that backup startegy. I
>> don't recommend backup to a second partition because it leaves you
>> susceptible to simultaneous loss of the original and backup to many of
>> the most common dangers: head crashes, severe power glitches, nearby
>> lightning strikes, virus attacks, even theft of the computer.
>> In my view, secure backup needs to be on removable media, and not kept in
>> the computer. For really secure backup (needed, for example, if the life
>> of your business depends on your data) you should have multiple
>> stored off-site.
>> My computer isn't used for business, but my personal backup scheme uses
>> two identical removable hard drives, which fit into a sleeve installed in
>> the computer. I alternate between the two, and use Drive Image to make a
> Partition Magic, in this simplified system, is almost superfluous, except
> of partitions.
> William B. Lurie
Bill,
It is wonderful to hear that at long last you are actually Drive Image 7
to make backup images which you can later restore if and when necessary.
This is a great leap forward from your previous grinding determination to
produce " Clones" of your master drive and the consequent booting
difficulties that you suffered.
You now only need one further small step to take you to Backup Nirvana. Get
yourself an external USB2 hard drive enclosure or a removable hard drive
sleeve for your e-machine. Backups images can then be made as often as you
like and, by using Incrementals, could be on a daily basis. It is common
sense to keep several days worth of backups. The only time that you would
then have to open the computer case would be to replace a failed internal
drive or other equipment.
Whole system backups may seem a bit over the top for the casual computer
user but the peace of mind and the ability to recover in under an hour from
most conceivable disasters is well worth the small extra expense. Not having
to decide what to backup is a bonus, one just backs up the whole system.
Good Luck.
Richard.
Reply to Richard
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Using Partiton Magic 8.0
There are 1247 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
