G
Guest
Guest
Archived from groups: microsoft.public.win2000.group_policy (More info?)
We use auditing SW in our organisation which runs every 30 days. Problem is
the SW would appear to attempt to write to the registry on the local PC which
tells the PC not to check for another 30 days when the audit is complete.
If when the audit runs i am logged in as a DOMAIN USER then then the process
runs in task manager (I can see the process when i hit CNTRL - ALT - DEL).
The process starts at 5MB but continues on to consume 256MB of memory and
then i start to get virtual memory errors and the PC also runs extremely
slowly. Thie processs will run all day without completing. If i kill the
process from task manager then the PC functions as it should. However as the
audit is not completing then the process starts all over again next time a
DOMAIN USER logs into the PC.
However, If i log on as an adminitrator then the audit process runs in task
manager and consumes 5MB of memory for about 2 minutes then kills itslef off
and won't run again for another 30 days.
1 - I don't want to have to do this every 30 days as there are 40 PC's in
the org running this.
2 - I also don't want Domain users to have local admin rights as the PC's
are locked down in order that users can't gain access to the registry , Run
commmand, Control Panel etc..
Question 1 - Is there anyway that i can give all domain users rights to this
application only to write to the registry of the local PC, without having
access to anything else in the registry.
Question 2 - I would rather not have to give DOMAIN USERS Power User rights
as this would lead them to installaing stuff i don't want them to have access
to.
Any help/Advice greatly appreciated
to.
