G
Guest
Guest
Archived from groups: microsoft.public.win2000.group_policy (More info?)
Profile Problem
I have a slight problem with all the users and there profiles on my network.
Basically my server crashed 2-3 months ago and I had to build a new server,
at this time I decided to move from sbs to server 2003 instead of going back
I thought might as well go forward and do this all at the same time (I had
out grown sbs and needed to upgrade anyways).
I manually created all my user accounts and restored the exchange, I then
restored all the users profiles.
When the users log on certain things don’t work, policies don’t work, they
can’t access outlook (says cannot start MS outlook), mapped drives don’t
appear, basically there are a number of issues.
I found out that it is because I created the accounts then restored the
profiles and they don’t link, the SID will be diff etc etc etc
When I get new users they are fine it’s just old users. I have fixed this
problem in a bad way but for now it’s got rid of the issue, I added all the
users to the Domain Admins group so now when they log on all works fine.
My urgent question is this, can I somehow re-create all the NTuser.dat for
all users, the only other way to do this would be to rename the old profile,
log on with a new, log out, copy the ntuser.dat from the new to the old,
delete the new profile folder and then rename the old back to it’s correct
name. This is a monstrous job to do for the amount of people it is for!
Anyone any ideas, I’m at my wits end lol
Thanks
Profile Problem
Thanks
