So yesterday I bought the MCE version of the PVR-150. Im running XP Home but it should still work. I have the irbus.sys and irbus.inf files in my system 32 folder. When looking at device manager under 'Other Devices' it says eHome Infrared Transceiver with a Yellow Question Mark saying drivers arent installed. I tried uninstalling and it just reinstalls the same ones. When i unplug the IR Blaster (It came with the IR blaster box and the ir transmitter cable) the ehome goes away, plugged in it comes back. However up at the top i have Infrared Devices listings saying Built-In Infrared Device. The remote is communicating with the blaster because the red little light is flashing, saying its receiving correct? Lasting going to the Hauppauge software and clicking BlastCFG i get a runtime error 429 - activex component cant create object and clicking IR Blaster Configuration it says IR hardware isnt installed. I installed all three drivers for the IR off the cd that came with cd. So what can i do to get the blaster to be recognized by Windows?
