Archived from groups: alt.cellular.cingular (More info?)
I just bought a Motorla Bluetooth headset (HS801). When paired w/ my V600,
the phone does not ring! It only rings through the headset itself meaning
that you have to have the headset on your ear in order to hear the phone
ring (unless of course it's on Vibrate+Ring in which case the phone itself
will only vibrate). I can't have the thing on my ear all the time! What
should I do?
that's a problem indeed. If I where you, since I've got no clue, I'd
simply call motorola, considering they are both motorola products,
maybe they have a solution for you, if not i'm sure they've got to be
able to provide yoiu with a solution.
>should I do?
>Thanks in advance!
>Amir
This is the reason I see so many Borg people wandering about with these
things sticking out of their ears. The only reason I use a BT headset
is for hands-free in the car. When I exit the car, the headset stays
behind.
