I installed 2 new memory sticks about 2 months ago. Everything 'seems' to be working fine, certainly in Windows and in most programs, but in World of Warcraft I've been getting some strange errors. After much searching around, it seems that it's the new memory which was at fault. I don't really know much about PC's, but I've tried switching the sticks over, running with just 1 etc, but I'm still having problems. It's very hard to know if it's the memory which is at fault, or the game itself.
I've just put both sticks back into the computer and run CPU-Z. I'm wondering if any of my settings in BIOS are incorrect because I just put the new memory in and didn't change anything in BIOS.
Below is the CPU-Z report. Could somebody tell me if there are any obvious errors which could be causing the memory to fail?
CPU-Z 1.38 report file
Processor(s)
Number of processors 1
Number of cores 1 per processor
Number of threads 1 (max 1) per processor
Name AMD Athlon 64 3000+
Code Name Winchester
Specification AMD Athlon(tm) 64 Processor 3000+
Package Socket 939
Family/Model/Stepping F.F.0
Extended Family/Model F.1F
Brand ID 4
Core Stepping DH8-D0
Technology 90 nm
Core Speed 1784.7 MHz
Multiplier x Bus speed 9.0 x 198.3 MHz
HT Link speed 991.5 MHz
Stock frequency 1800 MHz
Instruction sets MMX (+), 3DNow! (+), SSE, SSE2, x86-64
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 512 KBytes, 16-way set associative, 64-byte line size
Chipset & Memory
Northbridge VIA K8T890 rev. 00
Southbridge VIA VT8237 rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR
Memory Size 2048 MBytes
Memory Frequency 198.3 MHz (CPU/9)
CAS# Latency (tCL) 3.0 clocks
RAS# to CAS# (tRDC) 3 clocks
RAS# Precharge (tRP) 3 clocks
Cycle Time (tRAS) 8 clocks
Bank Cycle Time (tRC) 11 clocks
DRAM Idle Timer 16 clocks
Command Rate 2T
System
System Manufacturer System manufacturer
System Name System name
System S/N 123456789000
Mainboard Vendor ASUSTek Computer INC.
Mainboard Model A8V-E DELUXE
BIOS Vendor Phoenix Technologies, LTD
BIOS Version ASUS A8V-E DELUXE ACPI BIOS Revision 1003
BIOS Date 01/25/2005
Memory SPD
Module 1 DDR, PC3200 (200 MHz), 1024 MBytes, Micron Technology
Module 2 DDR, PC3200 (200 MHz), 1024 MBytes, Micron Technology
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
Processor(s)
Package Socket 939
Brand ID 4
Technology 90 nm
Chipset & Memory
Memory Type DDR
Command Rate 2T
System
Memory SPD
Software
