Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Question on wireless networking
I have to install a wireless solution for a friend .... his router will be about 30 feet + 1 floor (basement) away from the one he wants to connect to. i am not sure if the signal will go through the floor. was looking at this Dlink and was wondering if the signal will be strong enough ? could not find the info in the specs. Any help ?
thx :D
Sponsored Links
The only way to know is to try it.
Reply to FredWeston
Like most combo units it has low 2dbi gain antennas.
Use a seperate AP with High Gain (5+dbi) for a better chance. Floors can be hard to penetrate. Using a Seperate AP you have more option on positioning it for the best coverage.
And the problem may lay with the built in wireless if connecting to a notebook. There are a lot of them that are junk, most want the lowest power to save battery life.
Reply to blue68f100
thx for the reply. I had thought of seperate antenna for better reception. I talked to a friend today and he has a belkin g+ router and nic card for me to try tomorrow if that is not enough I will give the seperate ap a try also. The floor I have to get through is standard kitchen floor with ceramic tiling. and the remote comp is standard desktop.
thx again !
Reply to smartel7070
Don't put much faith in the Belkin.
They are not very reliable.
Everyone I ever delt with were junk and did not work. Brand new out of the box. And the ones that did work constantly dropped connections and locked up.
Reply to blue68f100
There are 1242 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
