Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Building first system, need help w/power supply
Forum Homebuilt Systems : General Homebuilt - Building first system, need help w/power supply
Want to build it my self. Have picked out parts but not sure on the power supply. Not a gamer, more internet, Office type stuff, multi media, kid games for my 11yr old daughter. Cost so far is $833 @ Tiger Direct.
Here is a list of the goods:
MSI 975X Platinum Intel Socket 775 ATX Motherboard / Audio / PCI Express / Gigabit LAN / S/PDIF / USB 2.0 & Firewire / Serial ATA / RAID
Intel Core 2 Duo E6300 1.86GHz / 2MB Cache / 1066MHz FSB / Dual-Core / OEM / Socket 775 / Processor
ThermalTake Jungle 512 / Socket 775 / Intel Prescott / Copper Core / CPU Cooling Fan
Crucial Ballistix Dual Channel 1024MB PC6400 DDR2 800MHz EPP Memory
Seagate / Barracuda 7200.9 / 160GB / 7200 / 8MB / SATA-300 / OEM /
Hard Drive
DiabloTek Radeon X700 Super / 512MB DDR2 / PCI Express / DVI / VGA / TV-Out / Video Card
Sony DRU830A / 18x DVD±R Burn / 16x DVD±R Read / 8x DVD+RW / 6x DVD-RW / 8x DVD±R DL / 12x DVD-RAM
Power Up Black ATX Mid-Tower Case with Front USB and Audio Ports and Touch-Sensitive Controls w/ 1 - 120mm front and 2 - 80mm rear fans
The video card recomends 350w ps but do I need one with plugins for the 3 fans as well? I saw some with the 120mm but nothing about the 80mm's.
From what I have read here you people know your stuff, so any advice would be helpfull.
Thanks...
Sponsored Links
As you are unsure about the psu, This will help. :wink:
Reply to Everett
well, i recommend fsp stuff, other people will recommend other stuff. for what you've got there though, i dont think you need anything too hefty. 600 watts will more then do fine. i say 600 because generally speaking, 500 watt psu's dont have enough amps on the 12V rails.
this one is 550 watts
http://www.newegg.com/Product/Prod [...] 6817104018
that psu 101 link above is an excellent resource. check it out.
Reply to pottymonster
First, you can get Y-splitters for more fan connections.. just depends on if your fans are 3 or 4 pin connectors.. fans don't use much power so don't let that be a factor into your power supply choice.
You're going to hear quite a bit of talk about power supplies.. if you're not overclocking the machine, you won't need more than 400W. See for yourself:
http://www.extreme.outervision.com/PSUEngine
Also, you should probably consider going with 2x512MB memory instead of one 1GB stick.. dual-channel mode is nice, and your motherboard has two more slots if you want an upgrade later.
Reply to -silencer-
silencer - not interested in overclocking and the memory is 2 sticks. I reasearched the dual channel memory. Thanks for the calculator link. It say's I need a min of 200w.
pottymonster - thanks for your input. Will keep an eye on amps thur the rails.
Everett - excellent link, to much info for this early in the am, will read thru after work.
Thanks to all who replied. I reasearched all other parts but did not realize psu was such an important piece of the pie.
Thanks again...
Reply to taker2112
There are 696 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
