Tom's Hardware > Forum > Windows 2000/NT > Windows 2000/NT General Discussion > Configure Power options in control panel for a group of PC's
Forum Windows 2000/NT : Windows 2000/NT General Discussion - Configure Power options in control panel for a group of PC's
Archived from groups: microsoft.public.win2000.group_policy (More info?)
Is there a way to configure Power options for a specific OU? I have looked on
both the server polic settings as well as the XP local policy settings- there
seems to be no way to configure power related GPO's. I would like to be able
to disable the monitor from turning off after 20 minutes.
Thank you for your time
Sponsored Links
The only way I was able to do this was to give admin rights to the user, log
in as the user change the settings then take the admin rights away. although
I still have had some issues where the setting will not hold no matter what I
have done.
Hope this helps
Bill
Reply to Anonymous
Hi,
Only the predefined themes, because the seperate Timesettings
are Reg_Binary and cant be manipulated via adm template.
I can give you a german ADM
http://www.gruppenrichtlinien.de/adm/powerscheme.txt
Google Translation is not really working ... :-(
HTH
Mark
Mark Heitbrink - MVP Windows Server
Homepage: www.gruppenrichtlinien.de
Reply to Anonymous
I thought about creating a regular user with admin rights - change power
settings in profile- take away admin rights - copy this profile to the
default user profile. That way anyone new logging in would recieve proper
power settings. That should work right?
Thanks
> have done.
> Hope this helps
> Bill
Reply to Anonymous
=?Utf-8?B?ZXhjaGFuZ2Vyb29raWUxOTk0?=
> looked on both the server polic settings as well as the XP local policy
> settings- there seems to be no way to configure power related GPO's. I
> would like to be able to disable the monitor from turning off after 20
> minutes.
Try here:
http://www.energystar.gov/index.cf [...] _pm_ez_gpo
Andy.
Reply to Anonymous
There are 1152 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
