Thank you in advance.
The small person next door (she’s 11) is having trouble with her computer.
When you turn the machine on the fan starts and the HD light at the front flashes, quickly. Also the light around the power switch flashes in unison. The CD and DVD drawers wont open. There are no lights lit on the motherboard, having said that I can’t see any that should be lit. I am testing the tower just on the power cable with nothing else connected, although I understand it was doing exactly the same when it was fully connected. It happened all of a sudden. The HD appears not to be running. I have rie holding the power button in for 40 seconds having rad a post with that suggestion, nothing changed. Felt around for loose wires. I have a multi meter if someone could point to me the connections to couple to.
If you could spell out the solution, or tests to carry out I’d be grateful, I won’t necessarily understand your expert abbreviations
E Machines 620
2.7GHz
Intel Celeron
80 GB HD Ultra DMA/100
3D AGP G Force FX5200 64MB TV out
512 MB DDR
48x CDRW
16x DVD
10/100 Mbps Ethernet
56 Fax Modem
Windows XP
Thank you
Ray
E Machines 620
2.7GHz
Intel Celeron
512 MB DDR
48x CDRW
16x DVD
56 Fax Modem
Windows XP
Thank you
Ray
