Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Quiet/silent Micro ATX cooling options?
Forum Homebuilt Systems : General Homebuilt - Quiet/silent Micro ATX cooling options?
I posted this question earlier to the Asus group, but it may be more appropriate here.
I'm feeling a little out-of-the-loop as I'm starting to think about buildingying another system. I'm starting to fucus in on a specific board (Asus P5B-VM) but my question is more general: Do motherboards (or this motherboard) generally come with stock CPU cooling for Core 2 Duo? I'm assuming some sort of CPU cooling option is necessary.
Otherwise, would someone recommend a quiet (or silent!) option for cooling the CPU on a board like this? I'm not planning to do much in the way of overclocking.
Thanks in advance!
Sponsored Links
I believe core 2 duo comes with a nice stock that should work fine if you don't overclock.
I'm not much of a computer wiz though.
Reply to nioin3k
Intel Core 2 Duo E6600 Conroe 2.4GHz
Cooling Device: Heatsink and Fan included
http://www.newegg.com/Product/Prod [...] 6819115003
hope that helps
Reply to nioin3k
Quote :
hope that helps
That helps a lot actually, thanks. I'm getting familiar with the different models (mobile, Conroe, and some other one). Did you quote the E6600 because it's middle-of-the-road price-wise? That looks like a good way to go.
Thanks again!
Reply to 3030vision
I made my mATX machine really silent. Now I can hear my drive seek. LOL
Just good fans and a quiet PSU.
yate loon's are cheap quiet fans. 4-10 bucks 28db
silenx are very quiet but much more expensive. 15-20 bucks 14db
gromets, gromets, gromets
Reply to Schmide
There are 1154 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
