Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Digital Connection to monitor?
Forum Graphic & Displays : Graphics Cards - Digital Connection to monitor?
I have a nvidia 7900 gt and I just upgraded to a LG 19 inch Flatron monitor. IF the, I believe it is a DVI cable and connect that from the GPU to the monitor, will there be much of a better picture or is the twenty bucks for the cable better off somewhere else?
Sponsored Links
compared to what? an adapter for rgb?
better to just connect dvi to dvi.
Reply to sirheck
well out of the video card is a DVI connector but I have an analog adapter that then analog adapts to the monitor. It's a matter of going digital i guess.
Reply to sexypants4all
- 0 +
it will work either way.
Reply to sirheck
Quote :
Sorry but I'm not asking about it working either way. Because I wouldn't be seeing this right now if it didn't work. I'm just curious about the video quality that you get from a DVI to DVI connection as compared to an adaption from DVI to Analog.
I guess it just begs the question of whether or not you are experiencing any noticable degredation in your picture quality. If you think that it looks bright and crystal clear, then it's probably ok. For the record, yes digital will look better and produce a better picture, that's why it's used, but it really is a matter of personal opinion. If you think it looks great and don't want to spend $20 on a new cable, leave it alone.
Reply to nvalhalla
you wont be digital with a crt monitor, no buts to it, thats just a extra plug- in for a extra monitor. Now if you have a digital display you can have the option to use digital
Reply to gomerpile
hey thanks for all the input, appreciate it!
- 0 +
Quote :
it can be digital. depending on the crt.
Reply to sirheck
There are 702 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
