double-click on mouse
Forum Windows XP : Windows XP General Discussion - double-click on mouse
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I used to be able to dbl-clk mouse to open a folder - now when I dble-clk a
search window opens - how do I stop it - anybody know a remedy ?
Sponsored Links
MVP Doug Knox has written a small script file that will correct this
behavior. See http://www.dougknox.com/xp/scripts [...] r_open.htm
for more info.
Tom Porterfield
MS-MVP Windows
http://support.telop.org
Please post all follow-ups to the newsgroup only.
Reply to Anonymous
Go to your mouse settings:
Start | Settings | Control Panel | Mouse | Buttons
And change the behavior of the middle mouse or dbl-clk option (depending on
your mouse software)
Reply to Anonymous
Issue: Search Companion Starts If You Double-Click a Folder
This problem occurs when you alter the "Drive" / "File Folders" entries via
File Types dialog, to add a "Command Prompt here" or "Print Directory"
feature for folders. (example)
http://support.microsoft.com/?kbid=321379
http://support.microsoft.com/?kbid=321186
Click Start/Run and type this command to fix this problem:
regsvr32 /i shell32.dll
(Courtesy of David Candy)
To fix this manually via registry:
If this problem is seen for Drives:
HKEY_CLASSES_ROOT\Drive\shell
Set (default) to "none" (without " )
If this problem is seen for folders:
[HKEY_CLASSES_ROOT\Directory\shell]
Ramesh, Microsoft MVP
Windows XP Shell/User
http://windowsxp.mvps.org
"Fenella" <Fenella@discussions.microsoft.com> wrote in message
news:8C3F62F7-364D-4375-95FE-411833BCD62B@microsoft.com...
Reply to Anonymous
I tried your suggestion - unfortunately it didn't work ! but thanks for trying.
Reply to Anonymous
BIt worried about your suggestion - how do I reverse it. I've now tried reply
from Ramesh and it worked ! Great. Thanks.
> for more info.
> Tom Porterfield
> MS-MVP Windows
Reply to Anonymous
Thank you very much. it WORKED - Great. Again thanks.
Reply to Anonymous
You're welcome!
news:01726BF3-33CF-4BE6-AC77-649F69001C5C@microsoft.com...
>> via
<snip>
Reply to Anonymous
You wouldn't want to reverse it as doing so will get you back where the
default is search rather than open. Doug's script simply corrects this by
setting the default action back to open as it should be. Glad to hear you
got it fixed though.
Tom Porterfield
MS-MVP Windows
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > double-click on mouse
There are 1407 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
