Power and GPS lead compatability question
Last response: in Cell Phones & Smartphones
Anonymous
April 24, 2005 3:14:34 PM
Archived from groups: microsoft.public.pocketpc (More info?)
I have a Medion MDPPC250 PPC which came with a wired Medion GPS aerial, and
cigar lighter, power combo. (GPS sits on dashboard, and is powered via cigar
lighter, which then attaches to the bottom of PDA)
Will this setup attach to a new Dell Axim X30 in the same way, or do I need
to get another GPS/power supply unit? I think I know what the answer is
going to be, but I would really rather not have the expense.
Cheers
Chris
Anonymous
April 24, 2005 5:23:30 PM
Hi
It is not a stadard, and normally they are not compatible, could be a pretty
expensive if you tried. Many GPS recievers do have converter cables so you
could get it to fit the axim.
Regards,
Allan Boegild Pedersen
www.pda-faq.com
"Evil Uncle Chris" <chris.macnamara@ntlworld.com> skrev i en meddelelse
news:ucLae.4044$wu2.410@newsfe1-gui.ntli.net...
>cigar lighter, which then attaches to the bottom of PDA)
> need to get another GPS/power supply unit? I think I know what the answer
> is going to be, but I would really rather not have the expense.
> Cheers
> Chris
Anonymous
April 24, 2005 5:23:31 PM
".1176@TK2MSFTNGP12.phx.gbl...
> Hi
> pretty expensive if you tried. Many GPS recievers do have converter cables
> so you could get it to fit the axim.
> Regards,
> www.pda-faq.com
Thanks Allan, do you know of anywhere I can check compatability for one of
the convertor cables?
Cheers
Chris
Anonymous
April 24, 2005 8:21:13 PM
news:6uLae.4048$wu2.3744@newsfe1-gui.ntli.net...
I think you should try searching for a website for the GPS reciever....
Regards,
www.pda-faq.com
