I just built my first system. Got it up and running earlier today.
As for cooling, in addition to the Tuniq Tower, which I have on low, there is a chipset fan that comes the mother board, 1 120mm (that came with the case) in front of the raptors in the 4 in 3 module, an apevia 120mm above it, a 120m fan (that came with the case) in the back, and another 120mm apevia in the top.
What do you recommend. Should I get quiter fans? If so what fans do you recommend? Also what fan controller do you recommend?
Thanks.
E6600
EVGA nforce 680i
EVGA 8800 GTX
2 gb crucial bassalix pc 8000
2 WD 150 Raptors in raid 0.
Tuniq Tower 120
CM Stacker 830 evolution
Thanks.
E6600
EVGA nforce 680i
EVGA 8800 GTX
Tuniq Tower 120
