enthernet problem
Forum General Networking : Network General Discussions - enthernet problem
how to use the enthernet?
i want to connect my laptop to my desketop
i connected the cable but its not workin
Sponsored Links
The name is Ethernet and Ethernet is how the data is sent across the wire(The Format as it were), Have you made sure you're using a Cross over cable and not normal straight through cable or if you are using a Hub you are using straight through cable?
Could you please explain more about your setup.
Reply to ATLANT3AN
im using the ethernet cable directly from my desktop to my laptop.
i checked the connection n it say "connection is limited or no connectivity"
Reply to bulkypc07
You can setup Interent connection sharing with 2 networks cards on one computer and a crossover cable to the other computer's network interface card, but I would recommend purchasing a router and setting it up between the modem with a straight thru cable. Then add two straight thru cables for the 2 computers. Manage your password, id and other settings directly by logging into the router.
Routers are not that expensive. You can choose a wired router in your case. They also sell wireless routers, which have both wired and wireless.
Reply to evongugg
How did you determine that it isn't working? Type [code:1:1cb58f93f5]\\<ip addr>[/code:1:1cb58f93f5] on one computer substituting the IP address from the other computer. As a best practice, you should either assign static IP addresses one each computer or use another protocol like NetBEUI. It should work the way you have it though.
Reply to FredWeston
in the tray bar i checked out the local area connection and it says
"connection is limited"
so whats the problem?
Reply to bulkypc07
There is no problem, see my previous post. Windows is complaining that it could not contact a DHCP server to lease an IP address.
Reply to FredWeston
i dont get it, where to type the //<ip addr> ?
can you make it more detailed n simplier.
its my 1st to connect two computer n im really clueless :oops:
Reply to bulkypc07
In the run dialog, Windows Key + R.
http://img482.imageshack.us/img482/6909/runsl8.th.jpg
Go to the other computer and open a DOS prompt, Start => Run => "CMD" minus quotes.
Type "ipconfig" and note the IP address.
Now substitute that IP address where I have 172.16.1.15 in the pic.
Reply to FredWeston
thnx, now i have network, now it says "connected" but
1.i cant use my internet in my second computer
2. I cant play(connect) in LAN games
but i can share data's now
n wait im using old fashion dial by now. :lol:
Reply to bulkypc07
Quote :
Umm, you never said anything about using the Internet on the 2nd computer. Maybe you need to back up and tell us exactly how you have everything set up.
Reply to FredWeston
i like to play lan games with my sister but i cant connect the two computers.
i want to surf internet/play online rpg's with my sister n cousin
but when i connect the main computer ,the other one cant connect to internet.
Reply to bulkypc07
If you want both of them online then you should really buy a router. You can do it with ICS but there are lots of limitations. ICS info.
Reply to FredWeston
Tom's Hardware > Forum > General Networking > Network General Discussions > enthernet problem
There are 490 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
