Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > HELP!!!! Win XP doesn't start!!!!
Forum Windows XP : Windows XP General Discussion - HELP!!!! Win XP doesn't start!!!!
Archived from groups: microsoft.public.windowsxp.basics (More info?)
HELP!!!
When I was about to start installing MSDN for Visual Studio 6, the installer
program hang. It hung so heavily that I couldn't even end the installer
through Ctrl+Alt+Delete. When I closed down the computer I got some error
(which I now can't remember), but I selected to close the program and then
the installer finally ended. But when I restarted Windows I get some message
like this:
Windows could not be started. This might depend on a change in soft- or
hardware.
If this depends on that the computer didn't answer, restarted unexpectedly
or was closed down automatically to protect your files and folders you can
choose "Last working configuration" to reset the settings which were used the
last time the computer successfully could be started.
If a previous startup was interrupted by a power cut .... or if you are not
sure why you computer cannot be started you can choose "Start Windows
normally".
Failsafe mode
Failsafe mode with network
Failsafe mode with command prompt
Last working configuration (the last settings which worked)
Start Windows normally
But it doesn't matter if I choose "Last working configuration" or "Start
Windows normally". Whichever I choose, all I can see is the Windows XP start
up screen with the progress bar. This progress stops quite soon after it
started and then the computer is restarted. What has happened here????
Sponsored Links
If you find it necessary to post to more than one group at a time, please
crosspost as opposed to posting individually to each group. I've responded
to you in the windowsxp.accessibility newsgroup.
Michael Solomon MS-MVP
Windows Shell/User
Backup is a PC User's Best Friend
DTS-L.Org: http://www.dts-l.org/
"Joachim" <Joachim@discussions.microsoft.com> wrote in message
news:46AED27A-B22E-4F31-B1A0-D3BCEEE778D4@microsoft.com...
> HELP!!!
> installer
> message
> like this:
> hardware.
> the
> not
> normally".
> Failsafe mode
> start
Reply to Anonymous
Hi Michael,
It is such a critical error to me so I wanted to be sure that the right
people saw my post. But I'm sorry if it is annoying. What does crossposting
mean?
Kind Regards,
Joachim
> Windows Shell/User
> > HELP!!!
> > installer
> > message
> > like this:
> > hardware.
> > the
> > not
> > normally".
> > Failsafe mode
> > start
Reply to Anonymous
You're using the web interface and I'm not sure if it's possible to use that
interface to crosspost. Crossposting is the creation of one message that is
sent to more than one group at a time. Most newsreaders have this
capability including Outlook Express, the reader that ships with XP though
usually, even crossposting should not be necessary.
Nonetheless, when a message is crossposted, answers in the thread in one
newsgroup appear in all the others. That way, users don't have to go group
by group to see if a question has been answered and neither do you. If you
individually post to several groups, then no one knows, including you, if a
question has been answered elsewhere and you have to take the time to go
through the groups to find out. Other users, find it annoying to see the
same question individually posted as opposed to crossposted for that reason
as well.
Check the following for information and instructions for setting up Outlook
Express as your newsreader:
http://www.michaelstevenstech.com/ [...] reader.htm
Windows Shell/User
news:8DEC34BA-1E32-4A80-803A-9B84743B189D@microsoft.com...
> Hi Michael,
> crossposting
> mean?
> Kind Regards,
> Joachim
>> responded
>> Windows Shell/User
>> > HELP!!!
>> > installer
>> > error
>> > then
>> > message
>> > like this:
>> > hardware.
>> > unexpectedly
>> > can
>> > used
>> > the
>> > not
>> > normally".
>> > Failsafe mode
>> > "Start
>> > start
>> > it
Reply to Anonymous
I have the same loop problem with XP. Is there a key combination to start in
Safe Mode?
Jack
> Windows Shell/User
> > HELP!!!
> > installer
> > message
> > like this:
> > hardware.
> > the
> > not
> > normally".
> > Failsafe mode
> > start
Reply to Anonymous
Sorry if this is a dupe. My first time here and not sure of the process.
Asking if there is a key combination on startup to envoke safe mode in XP.
Jack
> Windows Shell/User
> > HELP!!!
> > installer
> > message
> > like this:
> > hardware.
> > the
> > not
> > normally".
> > Failsafe mode
> > start
Reply to Anonymous
Usually the F8 key. You can also reach safe mode with START>RUN type
'msconfig' ENTER and on the Boot.ini tab check Safeboot. Then restart.
Colin Barnhorst [MVP Windows - Virtual Machine]
(Reply to the group only unless otherwise requested)
"jackshipley" <jackshipley@discussions.microsoft.com> wrote in message
news:3CA2CB62-F49E-4751-BE7C-DC7E075051A6@microsoft.com...
>in
> Safe Mode?
> Jack
>> responded
>> Windows Shell/User
>> > HELP!!!
>> > installer
>> > error
>> > then
>> > message
>> > like this:
>> > hardware.
>> > unexpectedly
>> > can
>> > used
>> > the
>> > not
>> > normally".
>> > Failsafe mode
>> > "Start
>> > start
>> > it
Reply to Anonymous
There are 1268 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
  • 01:00 rolli59 won the Spy badge
