Archived from groups: microsoft.public.win2000.group_policy (
More info?)
Here is a vbs script to modify Power settings:
Option Explicit
On Error Resume Next
Dim objNetwork, WSHShell
Const WindowStyle = 0
Const WaitOnReturn = True
Set objNetwork = CreateObject("WScript.Network")
Select Case objNetwork.UserName
Case "username1", "username2", "username3", "jpervan"
Set WSHShell = WScript.CreateObject("WScript.Shell")
WSHShell.Run "CMD /c powercfg /c ""Test""", WindowStyle, WaitOnReturn
WSHShell.Run "CMD /c powercfg /x ""Test"" /monitor-timeout-ac 3",
WSHShell.Run "CMD /c powercfg /x ""Test"" /disk-timeout-ac 3",
WSHShell.Run "CMD /c powercfg /setactive ""Test""", WindowStyle,
WaitOnReturn
Set WSHShell = Nothing
End Select
Set objNetwork = Nothing
HTH
"michael--" <michael@discussions.microsoft.com> wrote in message
news:51B94A1A-E453-4977-B042-833E1111985B@microsoft.com...
> theres is no policy for power options setting.
> however, u can do it in the alternative way, by using a batch
> simple deploy this batch to all your machine.
> it will brings up the power options page
> however, this only work in XP
> it you are using it on 2k, u need to remove one of the WshShell.SendKeys
> "^{TAB}"
> line
> just customize it by yourself
> the msdn library have lots of resources about wsf
http://msdn.microsoft.com/library/en-us/script56/html/wsMthSendKeys.asp?frame=true
> Script.wsf
> <package>
> <job id="vbs">
> <script language="VBScript">
> set WshShell = WScript.CreateObject("WScript.Shell")
> 'USE TRADITIONAL THEME
> WshShell.Run "control desk.cpl"
> WScript.Sleep 3500
> WshShell.AppActivate "Display Properties"
> WScript.Sleep 200
> WshShell.SendKeys "^{TAB}"
> WScript.Sleep 200
> WScript.Sleep 200
> WshShell.SendKeys "%o"
> WScript.Sleep 200
> </script>
> </job>
> </package>
> "Denis Wong @ Hong Kong" wrote:
>> Hi Ron,
>> User Config\Administrative Templates\Control Panel\Display
>> Screen Saver
>> Screen Saver executable name
>> Password protect the screen saver
>> br,
>> Denis
>> "Ron Hinds" <__NoSpam__ron@__ramac__.com> wrote in message
>> news:uzCiYZ2eFHA.3048@TK2MSFTNGP12.phx.gbl...
>> > How do I set the display Power Saving options - specifically, I want to
>> > change the "Turn off the monitor" option from the default of 20 min. to
>> > Never - for all users of a W2K computer, current and future? Also, I
>> > want
>> to
>> > set the screen saver the same for all users. TIA!
