Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Help: Starting a Wireless network
Forum Wireless Networking : Wireless General Discussions - Help: Starting a Wireless network
I would like to start a wireless network but some things confuse me.
The first thing is which version should I get 802.11b or 802.11g
Second what Security features should I look for like Mac Filtering, Wep, etc.
What brands should I stay away from?
I will be just needing it for regular use to connect to the internet. I have two PCs.
I'm really new to this so any help would be great thanks.
Sponsored Links
Understand, the following is my opinion, based on my personal experience.
Quote :
I'd definitely go with 11g. The difference is speed (5x faster) and security features (11b does not support WPA).
Go with 11b only if you are severely budget contrained, you are satisfied with sub-10Mbps performance, and you are isolated enough (physically) that you don't care about wireless security issues.
The various speed-booster wireless devices will mostly restrict you to the same brand equipment throughout. I have no experience with the now-emerging 11n - which is faster yet.
Quote :
You will need a firewall function at your point of connection to the internet. This is usually provided in the router. It may already be there, depending on how you get your internet service. On the wireless itself, if you need security, use WPA. This, as I said above, is only available on 11g and up equipment.
Make sure you change the default admin passwords on your wireless router setup screens, and change the default broadcast SSID name.
Quote :
Hawking.
Reply to Iceblue
- 0 +
Thanks for posting.
Quote :
What do you mean by this?
Reply to eofu
A lot of manufacturers have implemented their own "addons" to 802.11g. Sometimes you'll see manufacturers claiming 108mbps and the like. Typically this only works if all your equipment is from the same manufacturer. My advice is to stay away from anything that isn't an industry standard. 802.11g is a standard, and all 802.11g equipment will work together regardless what manufacturer makes it. Typically the manufacturer's call their enhanced products things like "speedbooster" or "rangeextender". If you only have two PCs, you can get by with a plain jane wireless router. The Linksys WRT54G or Netgear WGR614 are both good places to start looking.
Reply to FredWeston
- 0 +
Quote :
Thanks for posting.
What do you mean by this?What Fred said.
Reply to Iceblue
- 0 +
Alright. Thanks guys for your help
Reply to eofu
There are 1055 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
