Tom's Hardware Forums » Overclocking » General Discussions » Overclocking AMD 4000+ help!!
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Overclocking AMD 4000+ help!!
LANiMAL
Profile: member
More Information
Right, just want to ask a few questions about general overclocking as im quiet new to it.
I have a AMD 4000+ (stock 200x12)
Geil 2GB RAM the timings 3-4-4-8
Abit KN8
When i up my FSB to 225 i get 2.7ghz, this is stable on the stock Vcore. By raising this it makes my memory go to 225mhz.
It also makes my hypertrans go to around 1100mhz.
Questions
- If my memory only could handle 225hmz how can i still over clock my CPU? Would this be using the SPD setting?
-Do i manullay change the clock times on my memory?
-Is it right that you have to keep your hypertrans to 1000mhz around or below? This would be the HT multiplyer, mayber lowering it to x4?
-You up the Vcore to give a higher voltage to the CPU soo you can have a higher abliaty to raise the FSB/overclock your CPU more?
-How do i keep my memory running around 225mhz?
Thanks in advance!
Related Pr oduct
Add a reply
Google Ads
News
OCZ ships lower latency PC-4000 modules
Published on February 28, 2006
Performance memory maker OCZ announced PC-4000 modules with 3-3-3-8 timings. The 500 MHz devices join the firm's Platinum XTC series and are available as single 1 GB modules or 2 GB dual-channel kits. Read more
AMD pumps up notebook performance with 4000+ chip
Published on August 16, 2005
AMD today unveiled its fastest ever 64-bit notebook processor, the Mobile Athlon 64 processor 4000+. Read more
OCZ adds two more 2 GByte gamer memory kits
Published on November 15, 2005
Just in case you are still keeping track of the memory kits for gamers that are popping up for the Christmas season, here is another one for your shopping list. Read more
AMD expands 65 nm Athlon 64 X2 roadmap
Published on September 27, 2006
AMD will expand the roadmap for its 65nm-made Athlon 64 X2 CPU portfolio (codenamed Brisbane), with the series lineup adjusted to feature processor clock speeds differentiated by 100 MHz, instead of the 200 MHz, according to motherboard makers. Read more
Latest Reviews & Articles
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
Seagate's 1.5TB Barracuda: Bigger And Better?
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
