Latest Reviews & Articles
Life At 2 GT/s: 6 GB DDR3-2000 Memory Kits Compared
Memory vendors put a lot of effort into drumming up excitement over high-end memory kits, but many of those products turn out to be vaporware. We test six DDR3-2000 kits that enthusiasts can actually buy today, and push them as far as they'll go. Read more
DDR3 Memory Scaling On AMD's Phenom II X4
DDR3 memory is available in speeds ranging from DDR3-800 to DDR3-2133. Which is the best memory choice for AMD’s Phenom II X4? We tested as many speeds as possible using aggressive and conservative timings to find the sweet spot for your next build. Read more
Intel Core i7-975 Extreme And i7-950 Reviewed
Today Intel launches two high-end processors that take the place of its i7-965 and i7-940 CPUs. More speed? Same price points? We’ll take it! But are the new chips compelling enough to warrant spending more than you would on an i7-920? Read more
AMD Athlon II X2 / Phenom II X2 And Low-Power CPU Bonanza
Eager to let you know it’s been busy, AMD is launching four new processors today: the first Athlon II, a dual-core Phenom II, and two low-power 65W Phenom IIs. We bought ourselves a new Pentium E6300 and let loose with AMD’s latest. Read more
All the Reviews & Articles
Tom's Hardware > Forum > Home Theatre > HDTV > strange audio on mitsubishi HS-U778 recording hdtv
Archived from groups: alt.video.vcr,alt.tv.tech.hdtv (More info?)
taping from HBO HDTV.
recently tapings on my mits u778, when replayed, have been troubled
by a ticking clock sound, sounds like a wind-up clock going tick tock,
tick tock, ... annoying.
i pushed the audio button on the remote and was offered four
options: stereo, R, L, mono. the ticking is present on stereo and L,
not on R or mono. so i am replaying using the R setting.
where did the clock come from, and can i remove it and return to normal
stereo audio? is it in the hdtv signal or an artifact of the vcr?
i used to have a panasonic high end vcr in this position, and this
never happened at that time.
getting out of bed in the morning is an act of false confidence
- jules feifer
to email me, delete blackhole. from my return address
Sponsored Links
In article <1087236508.624701@irys.nyx.net>, awouk@blackhole.nyx.net (arthur wouk) wrote:
YOu basiclally have isolated it to the left HIFI audio channel. It could just
need a simple cleaning. Have you recently played an old or possibly grundgy
video tape( like a rental tape)? I suggest a head and tape path cleaning.
Reply to Gman
It's a bomb! RUN FOR YOUR LIFE! <g>
Reply to Anonymous
Archived from groups: alt.tv.tech.hdtv (More info?)
I have an SCPC analog receiver that has sub-IF frequencies that send
out a time-based signal that sounds like a clock......do you have one of
those old style analog SCPC units and it is cross-feeding audio somehow
through an audio circuit in an A/V receiver or A/V switcher? I know this
is a LONGSHOT,but I thought I would suggest it anyway.
Reply to Anonymous
- 0 +
Its a liberal conspiracy. Its on the left side
;o)
Reply to Gman
OOOH...better follow that with a <gdr>, eh? Good one...
Reply to Anonymous
In article <2829-40CE18E5-491@storefull-3252.bay.webtv.net>,
SAC 441 <SAC441@webtv.net> wrote:
:I have an SCPC analog receiver that has sub-IF frequencies that send
:out a time-based signal that sounds like a clock......do you have one of
:those old style analog SCPC units and it is cross-feeding audio somehow
:through an audio circuit in an A/V receiver or A/V switcher? I know this
:is a LONGSHOT,but I thought I would suggest it anyway.
so far in my tests, i have shown that a tape prepared on another
machine lacks the clock sounds. i am changing the tape in the mits
u778 to see if there is something on the tape which does this. i will
study my a/v receiver to see if it is doing something along these
lines. (it is behiving strangely in other ways at the moment so this is
not out of the question.)
- jules feifer
Reply to Anonymous
chnaging the tape seems to have cured it. the problem was in the
vcr.
- jules feifer
Reply to Anonymous
There are 785 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
