Yes No
Ads
Tom's Hardware > Forum > Cell Phones & Smartphones > Windows Mobile > wireless connection +"the page you are looking for cannot ..
Forum Cell Phones & Smartphones : Windows Mobile wireless connection +"the page you are looking for cannot ..
Archived from groups: microsoft.public.pocketpc (More info?)
I have an ASUS a730w and am trying to connect it wirelessly to my home
network which has a D-Link AirPlus Extreme G Wireless router (DI-624)
Eveb with the "g" setting turned off although my PPC shows me as
connected every page I try to go to with IE gives me the message "the
page you are looking for cannot be found"
I'm new to setting up a wireless network so any help would be
appreciated. Maybe I'm missing something.
If the settings on the router need a lot of tweaking how does this
work for hot spots etc elsewhere. I innocently thought I could find a
place with a free wireless hot spot, turn on the WiFi on the PDA,
look for an available connection, hit connect and surf. This isn't
working at all at home so how will it work elsewhere?
Most places you will be able to just turn on the wireless and it will pick
it up. I'm not really very familiar with your ppc but I do know of several
people that have had trouble with d-link wireless routers, me being one of
them. Once I went to a different brand router I had no problems. Might try
D-Links faq's to see if you can pick up any hints or even thier tech support
Reply to Anonymous
"Jane Austin" <janeaustin376@hotmail.com> wrote in message
news:qgq4711obj0l1e2kvfm2beff1kt2r2qn16@4ax.com...
I'm not familar with that model but is there anything under connections or
even programs that allows you to manage the wireless card of your PPC? If so
can you see if your getting a valid IP? It's well worth getting one of the
tools you can find out there to do some basic pings and traceroutes on the
PPC so you can figure out where your problem might be.
As far as connecting wirelessly to the Dlink product I've never had any
problem with my older B router however I have had issues with DLink super G
when you turn on encryption as well.
Reply to Anonymous
It shouldn't be difficult, as most PPC's you just turn
wireless on, and the connection should pop right up.
What are your firewall settings? www.aximsite.com has a
great wireless setup guide too.
xfiler
>-----Original Message-----
router (DI-624)
shows me as
message "the
would be
does this
could find a
the PDA,
This isn't
Reply to Anonymous
I've tried with and without firewall, also with and without WEP. I
check the Wireless configeration and it says "connected" but I can't
surf anywhere. I've turned Wireless G off on the router too but
nothing seems to make a difference
On Fri, 29 Apr 2005 11:42:04 -0700, "xfiler"
>xfiler
>router (DI-624)
>shows me as
>message "the
>would be
>does this
>could find a
>the PDA,
>This isn't
Reply to Anonymous
Could you give me an idea what to look for to do this so I can do a
google search? Thanks
Reply to Anonymous
It almost sounds like you're connecting but not being able to authenticate.
First to get things going try to turn off all security on the router and see
if you can connect.
Getting a utility to ping, check your name server, etc would be useful. That
would tell you at least whether you successfully got an ipaddress and name
server.
This posting is provided "AS IS" with no warranties, and confers no rights.
Please do not send
email directly to this alias. This alias is for newsgroup purposes only.
news:bmi571l86lk4uksbnfr2b5g90dqmfpu433@4ax.com...
>>xfiler
>>router (DI-624)
>>shows me as
>>message "the
>>would be
>>does this
>>could find a
>>the PDA,
>>This isn't
Reply to Anonymous
- 0 +
My two cents...
Try restarting everything, including powering off the wireless router.
Try pocketwinc available as a free download here:
http://ppcworld.home.comcast.net/ppc_wifi.htm
If those two things don't get you connected it is likely that it is in
your connections settings on your ppc, especially if you have had other
wireless devices connect to your router. You may have to go to the
connection settings and just try different things.
Reply to Shacky
Here's a few:
http://www.omegaone.com/PocketPC/PM.html
PcketMechanic. Will show your current IP and let you release and renew it.
There use to be a bunch of stuff at http://www.freewareppc.com/ but it seems
down right now.
http://www.ppcsoftware.net/release/tracert/
$2.99
Probably your best bet is:
http://pda.tucows.com/pocket/preview/390745.html (FREE)
news:eti571t02noe4gbbd3e6iso6d2u4v7d0sc@4ax.com...
the
Reply to Anonymous
There are 1846 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What Phone should i get?
By jvdlcr125, 24 days ago:
If your looking for something in the Samsung Galaxy family I'd suggest that you go with...
Best offers
Top experts
