G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I have been working on XP with SP1 with no problems.
However, I just got a new computer with XP and downloaded
SP2. Here are my issues:
1)during set up for XP for the 1st time, I was given two
blanks to fill in - name of & organization. I put my
intials in the name blank, however, further along i was
asked to select a user name & XP wouldn't allow me to use
my initials again. I don't know how i did it on the
computer before but didn't have this problem. is there
any way that I can change the name of the system file
created under Documents & Settings so it matches my user
name since i'm the only one on the computer?
2)when i try to copy files from the hard drive to my
flash drive using the My Computer prompts on the left and
when I have selected & click "Copy these Files" and I get
the pop-up screen with the Flash Drive already selected,
the pop-screen, however, does not show all the files
contained on the flash drive. In other words, only some
files are listed in this screen while many others are
missing altogether. But the files are there and if I pull
up the flash drive on its own in My Computer, they show
up fine. Just not in the "copy to" pop-up screen?
3)I'm also having word processing problems (lines
changing appearance for no reason on the screen) with the
exact same program I had when I was using XP before.
could this be an OS or SP2 problem?
Thanks, Donna
Thanks, Donna
