I have an ASUS A8N Premium Motherboard I just got today. I installed it no problem, flashed the BIOS so it will recognize the FX-60 and all is well until . . . You install windows. It goes through the file copying fine, then reboots to start in 32-bit mode. It displays the XP splash screen and then shuts down . . . Done. I can't get passed that. I've also noticed the boot time it takes to get to the BIOS is extremely long (maybe its this model or the 2GB of RAM takes a while to check?).
The only thing that has changed is the motherboard, and everything worked on the old setup. The otherboard was a ASUS Cheap-o (A8S-x maybe?) with SIS Chipset THAT DIDN"T EVEN HAVE DRIVERS FOR IT (not anywhere, just the default windows crap)!!! I ended up switching b/c my new vid card would benchmark @ 1/2 the score of my 7800GS. I figured it was the cheap-o chipset. . .
I was thinking maybe its my its not getting enough juice but I have a 600W Cooler Master, that I have been using in 2 systems for over 4 months now. In the BIOS you can see all the Rails and they seem to deliver the required voltage.
I guess the mobo could be a dud too. What are you thoughts? If its the motherboard that is bad, I say piss on newegg, they send nothing but bad parts. . .
My New Non-working system:
ASUS A8N-SLI Premium
Cooler Master 600W PSU
AMD FX-60 (939)
G Skill DDR400 (2 x 1GB)
PNY 8800GTS
Western Digital 200GB IDE HDD (My Raptor was DOA)
AMD FX-60 (939)
PNY 8800GTS
