Hi, I just recently bought a new computer and here are the specs..
CPU - Intel C2D E6400 2.13ghz
RAM - Corsair 6400 2GB
Mobo - Gigabyte GA-965P-S3
GPU - EVGA 7900GS
PSU - Enermax Liberty 500W
HD - Seagate 320GB
So.. I am having a few problems. First off, when I download a file that is about 155MB it would take like 30 seconds to move the file into where I saved it after it's done dling. Second, when I try to extract a 155mb file into a folder with winrar, it takes forever.. Also, when I turn on my computer, the Windows XP loading with the blue bars going by stays for like 30+ seconds, I was expecting that my computer should be able to boot much faster than that.
I am trying to run WoW on max settings at 1280x1024 completely smooth, can someone tell me if that is possible with this spec? Because I am getting occasional frame skipping. And in the nvidia control panel, is it best to leave the settings to application controlled?
So I got the computer up and running on my first try, however I feel like I did something wrong during the installation process. Can someone tell me how I can check that everything is running normally(performance-wise/temp etc.)? I updated all my drivers except the BIOS because I read that it was risky to "flash" your BIOS.
Sorry, this was my first time building a computer. Hope to get some replies, thanks!
GPU - EVGA 7900GS
HD - Seagate 320GB
