Has anyone ever tried a true thermal xfer liquid in their cooling systems? I work for a chemical company that manufactures a thermal xfer compound designed for extreme temps on both sides of the temp scale called Therminol. It is applied in many different industries and scenerios to either heat or cool a given process and I am curious if anyone has ever tried such a substance in a pc liquid cooling system and the potetial results compared to treated water. It is unique in that it does not break down or cause corrosion like water alone does. The only drawback I know of is that it is more viscous than water and could cause flow problems, but I'm not sure how bad. I do not have a liquid cooling system at the moment to try it out, but I am currently looking for a suitable system for personal use and I may just dabble in this very thing. If anyone has tried a similar substance I would be very curious about the results. Thanks. :idea:
