hey guys i just built a new gaming system last night with hopes of overclocking it but ran into some huge temperature problems. here what i have.
cd2 e6300
gigabyte ga-965p-ds3
tuniq tower 120
artic silver 5
2 GB patriot DDR2 667 PDC22G5300LLK
antec p180 case
wd 74 gb raptor
creative fatality x-fi extreme gamer sound card
ati x1950 pro 256
i get everything up and running flash the bios to f10 check my temps in core temp and idle is 55-60 at stock speed with the tuniq fan set at the highest speed!! to i take it back apart clean the cpu and tuniq check to make sure both are even on the surfaces put them back in reapply the artic silver 5, temps are still the same, i take it off one more time clean and make sure they are seated properly and reaply the as5 and temps are still 55-60 at idle. i know these are ridiculously high temps for idle for the tuniq combined with this case and as5. i have no idea what is making my temps skyrocket. on top of that the memory is only running in single channel, im not sure if i would have to raise the voltage to get it to run dual channel. any help would be appreciated. thanks.
cd2 e6300
tuniq tower 120
artic silver 5
antec p180 case
wd 74 gb raptor
ati x1950 pro 256
