Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Need Advice on first build
Forum Homebuilt Systems : General Homebuilt - Need Advice on first build
Well I am about to get my tax return money back and have decided it is finally time to quit upgrading my old machine and get an all new one since I am still running an AGP board I will need to replace pretty much everything anyway. I have a good amount of experience with putting parts in, but I haven't done a complete from scratch build yet. I plan on using this computer for gaming and I also will probably want to overclock it mildly eventually. So any tips would be appreciated. I have a budget of around $1300 and here is what I have picked out so far -
Case - Coolermaster Centurion 534 Link
CPU - Intel C2D E4300 Link
Mobo - GIGABYTE GA-965P-DS3 LGA 775 Intel P965 Express Link
RAM - G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Link
Video Card - EVGA GeForce 8800GTS 640MB 320-bit Link
Hard Drive - Western Digital Caviar SE16 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive Link
PSU - OCZ GameXStream ATX12V 700W Power Supply 100 - 240 V Link
OS - Microsoft Windows Vista 32-Bit Home Premium for System Builders Single Pack DVD Link
All of this puts me just under $1300. I am going to use the DVD burner I have from my old box so that is one thing I don't need, as well as my monitor, which is a 20'' Dell LCD widescreen btw. Basically will all of this stuff work together and have I made pretty good choices or are there some parts I should swap out for other ones, I am very open to advice.
Sponsored Links
You just saved me time for typing up the same list. lol. Thumbs up!
A little tip for installing vista: Since vista drivers are either beta or unavailable, you should install your old xp, all xp drivers from the cd's, & lastly insert vista dvd in xp to upgrade. I did this to install ultimate on my friend's laptop. Working perfect.
Reply to akhilles
Like the previous poster said your system looks good.
You might want to wait until Vista's first service pack and more driver support before upgrading.
Reply to just2good4u3434
There are 1331 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
