Hey I have major problems with my wireless care Linksys WMP11..Im running windows me and when i start my computer sometimes it will connect and other times it wont...i have tried rebooting my computer and nothing....but when im lucky and it connects it will stay on for maybe 10 mins and then disconnect and will not re-connect..if anyone can help me plz tell me what to do cuz im getting really pissed at this thing.....thanks
Where is your router or access point compared with where your computer is located? How far apart are they? Any obstructions between them (walls, floors, filing cabinets, etc)? Is either near a microwave oven or a 2.4GHz wireless phone?
Well see my uncle has the router in his room...and i have no clue wats its setup is..but we have 6 computers hooked to it and none of them have problems with connecting only mine....and i have a microwave like30 ft from my room....is there something i have to install or maybe configure....
All of my questions were directed at interference and/or obstructions.
Since you seem reluctant or unable to answer, what signal strength to you see at your computer? Is it steady, or does it come and go (the signal, not your connection)?
Microwaves and wireless phones have been known to cause interference.
Walls and other physical obstructions (cabinets, bookcases, etc.) will weaken the signal, as will distance.
Can your computer "see" any other wireless networks (even if the signal is weak)? If so, are they on the same channel as your uncle's? If they are on the same channel or a "close" channel (e.g. he is on channel 1 and the other one you see is on channel 4), that also can cause interference.
Are the 6 computers that do not have problems located near yours, or are they in a more favorable location (closer, fewer walls between them and the rounter, etc.)?
Since you don't know what the physical setup of your uncles router is, does that mean you are poaching his signal? If not, then maybe you should ask him where the router is and what is between it and your computer.
