I recently upgraded my computer to a Pentium 4 3.0ghz @ 800mhz Northwood processor with Hyper Threading enabled (waiting for the core 2 duos to come down in price a bit). Everything seems to work fine except that my system monitor shows erratic temperatures in the processor zone at times. It generally idles at around 109-111 degrees Fahrenheit, but will jump sharply to 170 in only a matter of seconds & whilst performing the most seemingly-menial tasks such as visiting certain websites, playing video, etc... Then, within a matter of seconds after closing everything, it will sink back down to its idle temperature. This can't be normal, can it?
The only things I changed during installation were the heatsink/fan & the type of thermal compound I normally use. I had been using Arctic Silver 3 but switched to Ceramique after having run out of AS3. The heatsink and fan are stock. I am not attempting to OC nor do I play games much, so the stock heatsink/fan should do the trick. Or am I mistaken? The heatsink fins are cold to the touch during all of that I might mention. If anybody might have an idea to what might be causing these erratic temperatures, I'd appreciate any advice.
